Turbine 101 >
Turbine 101
Turbine 101
Old 10-18-2010 | 11:26 AM
  #691
yes Narragansett bay
I run in narragansett bay quite often...Where abouts do you run? I would like to take a peak at the boat sometime next summer...if you dont mind of course...
1MOSES1 is offline
Old 10-18-2010 | 12:30 PM
  #692
Sick Stinger's Avatar
Brotherhood #1
bristol prov. fall river neport block.
-Mike
Sick Stinger is offline
Old 10-20-2010 | 06:01 PM
  #693
KNOT-RIGHT's Avatar
Originally Posted by 1CE
How much over-all weight did you remove approx. ??? -
A guess would be 400lbs Remember it was filled with water.
KNOT-RIGHT is offline
Old 10-20-2010 | 06:57 PM
  #694
Brotherhood #1
Correct with water,not with air like my head
-Mike
Old 10-25-2010 | 10:44 AM
  #695
Coolerman's Avatar
PF Marine
Thumbs up
Originally Posted by KNOT-RIGHT
all this replaced by this unit.
that is cool.....
Coolerman is offline
Old 10-28-2010 | 09:06 PM
  #696
KNOT-RIGHT's Avatar
Originally Posted by saxman
that is cool.....
here is dexters version
Saw the video of your run at the shootout. Great Job Saxman!
Old 11-01-2010 | 02:59 PM
  #697
Default brake controls
that is cool.....
SAX how r ya ! I have 1on the trl., but G has 2 mounted in the hull. --
I'CE is offline
Old 11-02-2010 | 09:20 PM
  #698
-Mike
Dude, u need air under your hull not in your head as u have confessed too
I'CE is offline
Old 11-02-2010 | 09:22 PM
  #699
Nice loooooooookin units ! -
I'CE is offline
Old 11-02-2010 | 09:36 PM
  #700
KNOT-RIGHT's Avatar
they looked to be a better unit.
Both units produce 1600 psi.
When they are wired We use the breakaway circuitry.
in its intended application they are wired to a electric brake controller.
