-   Skater (https://www.offshoreonly.com/forums/skater-42/)
-   -   Anyone here used foot/ hand throttle in a large cat ? (https://www.offshoreonly.com/forums/skater/309448-anyone-here-used-foot-hand-throttle-large-cat.html)
bripar77 03-11-2014 02:47 PM
I have it on my Skater and wouldn't have a Cat without it. I am right handed and I sit on the left and so the sticks are on my right and I still use the Foot throttle 90% of time while boating. Gives me a better feel that if something happens to a drive on one side only I might better control the pull to one side that may occur. GT Perfomance (Upland, Ca.) Installed it on mine. Mine is set up to twist your foot if you want to control each engine seperatly ie: provide a little more to one than the other.
KEVLARKAT32 03-11-2014 03:51 PM
I take it is not the type that you still have hand throttle option ? Any issues in the rough stuff ?
I have done some research . CP performance offers a single or dual engine foot throttle ( N-CONTROL ) DOES NOT offer hand control as option . The N-control is MFG by mayfair and they may offer hand / foot throttle in future.
IN -CONTROL was the company that made the foot/ throttle , NO LONGER IN BUSINESS .
Rik 03-11-2014 05:17 PM
You can slave a hand throttle to the foot and vice versa if one wants both.
A normal foot throttle can be modified by cutting it in half and attaching a morse cable to both halves and then throttle on. It's not that difficult.
In Control made a split foot throttle. If CP does not offer this ask them if they can modify the throttle for you. In Control quit this a few years ago.
KEVLARKAT32 03-11-2014 05:54 PM
The IN- control offered the option to have had throttle work in tandem.
with foot throttle
THIS IS NOT TO BE CNFUSED WITH DUAL ENINE SPLIT PEDAL . I'm not sue were on same page .
Cobra100+ 03-11-2014 07:12 PM
I have the same set up on my Spectre and love it. I tend to use the foot throttle alot when just cruising around as well.
skate 03-11-2014 07:25 PM
Photos please!
KEVLARKAT32 03-11-2014 09:10 PM
Yes I would like some pics , send them to [email protected]
Your like me , refusing to pay to post pics here , hell without us there would be no OSO !!
Is the spectre OB and if so do you have power steering ?
Any issues at all in rough water ?
I had foot throttle in 13 ft tunnel boat years ago and had zero issues , actually seemed natural
Onetime 03-13-2014 10:50 AM
In-Control made the Hand/Foot Throttle set up. I rigged a few boats with them and they worked perfect. The ones I did used the split peddle foot throttle.
It seems that N-Control is not making the Hand/Foot adapter kit.
315duramax 03-13-2014 12:13 PM
why not build yourself a center console and put the sticks on the right side of the left seat???
KEVLARKAT32 03-13-2014 06:18 PM
NOT SURE WERE ON SAME PAGE OR READ MY ORIG POST
Rigging my 32 soon and after 30+ years of right hand throttling not sure I will ever be comfortable with left hand console mounted throttle . For that reason been looking into have split system . I thought I saw a system that you had the option to either use foot or hand throttle . Also concerned performance in rough water .
Any input and or exp would be great .
Larry
