Outboard skater BS thread!
#301
#303
I have run 98 so far with the bravos and half tanks. My new cleavers are much better with more stern lift and less bow lift. I have not had the opportunity to test top end speed yet. Mid range is stronger.
#304
From: East Texas Waterfront- running errands if anyone asks
#305
Definitely needs weight up front. Third motor is going to be a lot of weight to overcome. CG will be a challenge. A ballast tank might be the best answer. It would certainly put speed numbers very respectable with triples. I ask Pete to build a 32' flat deck with triples and he was not interested. Does anyone no anything about the triple engine flat deck 32' at Desert Storm this year. It really looked good.
[ATTACH=CONFIG]528438[/ATTACH]
#306
Boat sold a few years ago on OSO originally had twin 300xs motors. I think they added a third and he was not happy with it and switched to x motors. There is some video of it running on you tube at Desert Storm. Boat is running flat and fast. I know of another 32 with some modified triple x motors running low 120's. Here is a pic.
#309
So I need some hints on preserving the life on 300XS lower's especially the starboard counter rotation. I change the gear oil like clock work every 10 hours but the amount of metal filings seen worries me.
Use that Merc racing gear oil - is there something better?
I was told not to shift so much but you got to get in &n out of port - so....
#310
if he took the trips off and went back to twin X's I'd be interested in what his experience was and the reason to go back to twins... I'd have thought I would have sat lower in the rear as well. wonder if he added some weight to balance it out a little?
