Outboard skater BS thread! >
Old 08-27-2014 | 08:18 PM
  #311
I added the Taylor Billet shift shaft and vertical shaft carrier, and run a little less than full drive fluid....still check the fluid every time I run......weak link in the 300XS.....as far as I know...No changes have been made by mercury to correct the water intrusion problems.
offshoresteve is offline
Old 08-27-2014 | 08:36 PM
  #312
He went from twin xs's to triple xs's and then to x motors. I agree that there may be weight up front as well. But if you watch the video from DS that thing runs awesome. Fast and Flat!
Double Rigged is offline
Old 08-27-2014 | 08:41 PM
  #313
Originally Posted by Oceans15
So I need some hints on preserving the life on 300XS lower's especially the starboard counter rotation. I change the gear oil like clock work every 10 hours but the amount of metal filings seen worries me.
Use that Merc racing gear oil - is there something better?
I was told not to shift so much but you got to get in &n out of port - so....
When you say you have a lot of filings it is hard to gauge what you have. Can you post a pic of the drain plug? I also run the taylor shaft seals. Lakeside vent kit. I shift my motors a lot down here. Have not had any issues with metal. How old are the motors and hours on them. Is the idle high? Has anyone worked on them? If so maybe not shimmed properly.
Old 08-28-2014 | 06:29 AM
  #314
With my 2.5 lus' when I ran 260s' I would change the drive fluid after two times out and had no problems. I would see some metal debris, but, after running three seasons without tearing them down they were in great shape when I had to repair them after hitting a log at 80 mph. Now that I have the 225 promaxes that very seldom see more than 6800 rpm I can go 10 hours easily without lu fluid change. I never shift in and out of gear while running. Just my preference. Also I use Sierra lu fluid. Nothing expensive or magic about it.
Please make sure to do a quick check of lu mounting hardware and steering assembly hardware. At the rpms we turn things loosen up. I need you guys to hang around until I can join the cool kids club!
The Talon Guy
bulletbob is offline
Old 08-28-2014 | 06:53 PM
  #315
Where can i find these parts?
Oceans15 is offline
Old 08-28-2014 | 06:56 PM
  #316
motors are 2002 - the marina that does my repairs is the best in town. Have the vent kit installed. low idle.
Oceans15 is offline
Old 08-28-2014 | 08:44 PM
  #317
If you are looking for the Taylor seals call Hydra-Tec in Lake Havasu. They have them. Depending on the case you have you may have to grind the housing a little to get it to fit.
Not a big deal.
Old 08-28-2014 | 11:49 PM
  #318
Here are some photos on my Flickr account from Supercat Fest
http://flic.kr/p/oF96qx
If the link above disappears add "h" to this them paste into you browser "ttp://flic.kr/p/oF96qx"
skate is offline
Old 08-29-2014 | 06:31 AM
  #319
Great Pics. Skate your boat looks really good! Love the green and silver colors! Thanks for posting...
Old 09-02-2014 | 02:41 PM
  #320
Originally Posted by Taboma
I'm going to take it in to Tulsa today and we will see. I cannot find a hole , but there are parts of rod and piston in the bottom pan. I assume that piston/rod fragments came out the exhaust and hit the prop. The damage (pits in the metal ) started at the root of the blades and radiated out to the leading edge. It also looks like rollers from the bearing bounced up the center of the blades. They left rust stains on the blades.
David,
Any news on the engine? What did the find?
