Outboard skater BS thread!
#641
I was kidding about it being too rough. I would imagine they had too much to loose then gain by running the boat. It is a bigger heavier boat then the 28 skater and has 200 more hp, so in a little bit of cross wind and chop it would probably be faster then the skater. But anything other then a perfect condition for that boat I would put my money on the skater.
#642
#643
heard yesterday that is someone else out there has a 29 dcb with 400's on order. I love the look and rigging of thr dcb's...never been out in one so can't say anything about the ride and handling.
#644
#645
Hey Guys,
Was having some issues with my motors under full load with larger props and found we were not getting full RPM. Upon inspection of many things we found that the factory installed Skater fuel pick ups with the flare fittings installed were restricting the fuel by over 40 percent on one side. With the flare screwed in the threads went in too far and blocked the 3/8" hole. Not to mention the hard right angle. If you pull out the pick up look down the tube with a light shining in and see if yours might have the same problem. Funny thing that for years with my Opti's the Stbd engine would burn more fuel from time to time. Must have been on days I was running hard. Not sure if all the pick ups are the same but from what I tried to buy the ones I found were.
I know LA and Taboma had motor failures. This could for sure cause a problem.
So for these fuel thristy 300x's I replaced the pick ups with custom built stainless steel ones and added fuel pumps with all new aeroquip sweaping 90 degree fittings and a full 3/8" fuel line and fittings to the motors.
Just thought I would share what found. It may be worth checking anyway as a precaution.
#650
why the 90's at the bottom end of the pick ups anyway???? did not get into mine yesterday but this is really bothering me! lost the starboard with low hours so think I'm going to get to checking this weekend! def not going out until I see for myself what I've got!
