24 skater >
24 skater
24 skater
Old 10-09-2002 | 07:45 PM
big poppa pump's Avatar
Lightbulb 24 skater
what speeds are we looking at , for skater 24
w/ 2.5 260hp
or what else can be done to make this baby pump
any suggestion would be appreciated.
big poppa pump is offline
Old 10-10-2002 | 12:55 PM
skatermike24's Avatar
Should be around 105, whats your engine height?
skatermike24 is offline
Old 10-10-2002 | 04:39 PM
Skaterfast
Talking Re: 24 skater
Should be more like 115.My 24 with 225 promax motors goes a little over 100.
Old 10-10-2002 | 07:57 PM
Post skater 24
still putting motors together, get back to you on that
what about props 30 pitch or ? cleavers?
s
should they turn in or out
what about set back , i have jackplates about 6 inches ?
or should i go more or will it be a handling problem
Old 10-10-2002 | 10:54 PM
Skaterfast
Talking Re: Re: 24 skater
I cant remember for sure,but I think I have mine turning in for better handleing and a little less speed on the top.My boat is 250 miles away at the lake now.I'll look at it this weekend and let you know on which way they turn.
I am about 1 month away from installing 6" setbacks.I think the boat needs at least 6".I haven't had much luck on finding someone who has gone from no setback to 6" or more on a 24 Skater.I run 34" Merc 4 blades,the ones with the funky trailing edge.I haven't tried much else for props because everybody says thats's the prop to use on cats.Your boat would be a rocket ship all the way to 100 with 28" props.With the correct set up I think you will be able to pull 32" props.See ya.
Old 10-11-2002 | 09:09 AM
Ryan Beckley's Avatar
Racer
Racer
Lightbulb
I've got a pleasure 24 ( www.kineticanimation.com/skater.html ) I am running PROMAX 200's on cmc jackplates. I am turning 15x32's at 6200 at 95 MPH. Turning the props out makes the boat handle better but it is probably alittle faster but squirlly turning in. These boats like to run 14.5 3 blades. All the boats set up at Lake X run 3 blades. Withe 260's you'll see around 110-112.
Ryan Beckley is online now
Old 10-11-2002 | 11:37 AM
Skaterfast
Default Re: Re: Re: 24 skater
I'm pretty sure that mine are turning out then.Because I remember I set it up to handle beter.Sounds like I got a good runner,with no setback I've seen 102 on GPS.Looking for 104 or 105 with 6" setback in a month or so.
Old 10-11-2002 | 07:57 PM
Thumbs up skater 24
how much will the race hatch help?
still looking for one
Old 10-11-2002 | 11:45 PM
Racer
Racer
Lightbulb
The race hatch is worth a couple of MPH drop it down lower than even with the sides and it's faster too.
Old 10-14-2002 | 01:59 PM
IRONMAN's Avatar
How much lower like an inch or 4 inches? Thanks.
IRONMAN is offline
