New Skater under construction >
Old 06-25-2018 | 09:39 AM
  #211
Originally Posted by Double Rigged
The reason for the stern lift is from the thru-hub Dewald’s versus the over the hub cleavers from Mercury.
The Dewald’s with a hub are an extension of the gear case creating lift in the transom. Thus in theory making the motors higher. This will also have more of an effect on keeping the bow down also.
Ron, The addition of adding prop blades will also add stern lift, right? My conversations recently with Dave Dewald and my experience with going from 3 to 4 blades leads me to this.
Taboma is offline
Old 06-25-2018 | 12:37 PM
  #212
I think the number of blades make a difference for sure but regarding the transom lift IMO I think it depends on the rotation and extension of the gear case with the thru-hubs.
Double Rigged is offline
Old 06-25-2018 | 01:19 PM
  #213
LAriverratt's Avatar
Jim, with you having the ballast tank there's a lot more room to tweak I'm sure... the Mercs may very well be the best all around prop for you. I can only add bow weight the old fashion way
LAriverratt is offline
Old 06-25-2018 | 02:34 PM
  #214
You should be fine with the big stereo refit and all those subs up front!
Old 06-26-2018 | 07:06 AM
  #215
Registered User
So Jim, We actually met at the boat races when you and a friend of yours were at Sams watching the races this past season. Wasn't sure if you remember that. So I was wondering the Dewalds and the Merc cleavers you have used what the depths are that you have run each of them. I don't remember seeing that anywhere. Im currently running the 33 x 15 Mercury 5 blade cleavers. I also ran a set of Daves props with the bravo style hub. I ran 33 x15 but I don't think I ran them deep enough I kept the same heights as the Mercs. As they didn't run well on my rig. They were on the limiters at around 110mph. As I said I think Deeper would have worked better for that set. I wanted to try more pitch anyway so I traded them to some one in Long Island. His rig ran 116mph. A classic style 308. I ended up ordering and running Dewalds 34 x15.25 which we tuned a bit. They ran well but we never really finished their tuning as winter came and in Jersey Im done. We got them to within a couple mph of the Merc Cleavers. They ran smoother and the mid range was better but as you said the acceleration was better with the Mercs as I imagine they are over the blade exhaust and the props spin up faster. Anyway again I was wondering about the Depths you ran each set at. My rig has no notch in the lower transom and I have only 3 inch setback from my jack plates. My propshafts are at 2 inches above the bottom and could go a bit higher but I would need water pick ups like Ron did on his 308. A magnificent job he did I might add. I start losing pressure about there. Oh at optimal conditions Im currently running 116mph at around 7034rpm. I hope to improve that as I recently got a new powerhead and have been losing at least 35 to 50 horses on my starboard side since day 1 I had the boat. Maybe some of this above info can fill some gaps. Ron pretty much knows everything about my boat and is a tremendous asset here to us all. He could answer some things about similarities our rigs have. Mine is a 318 with 400Rs. I love it. Very close to yours but just different enough to possibly function/perform differently. Good luck with all of this.
Nastybug is offline
Old 06-26-2018 | 08:16 AM
  #216
Maybe this is a good place to continue the prop discussion. My questions are:
1. 3l Sportmasters torpedos are 4.88" dia., 400R's are 5.44" dia. Are the new Mercury CNC Thru hub props 5.44" dia. or the standard 4.75" dia?
2. What are the dia. of the thru hub Dewalds for the 400R application?
3. If the dia's. above are the std. 4.75", are the thru hub props effectively a combination of over hub and thru hub due to the "gap"?
Taboma is offline
Old 06-26-2018 | 07:57 PM
  #217
David not sure I understand the post regarding the prop sizes. Over the hubs are much smaller the dimensions of the gearcase hence why the are over the hub. In your post are you talking about thru-hubs?
Old 06-26-2018 | 09:14 PM
  #218
He was wondering if the thru-hub props were made to fit the larger 400R cases. Pretty sure they are motor specific Taboma.
AZMIDLYF is offline
Old 06-26-2018 | 11:09 PM
  #219
Don’t know if I’m any help here but I sold Ron my 32” thru hud Dewald’s. They are the 5.44 diameter as I remember. My performance was always less with them. Long hole shot poor midrange and 2-3 MPH slower than the Merc over the Hub. I got some 15.25 32” 15 degree from Merc at LOTO last September and could not run them in smooth water as too much stern lift. Great in rough water and I was 112 at Tickfaw this spring with fuel and poker run load. Those I sold to Jim and now have a set of 15.25 32” 18 degree being built. For note I bought a set of Merc Max 5 which are thru hub 5.44 hub diameter. Good bow lift and great overall performance but 3-4 mph slower top end. I use them for my beater props during spring and unfamiliar waters. As rigged my boat really likes them.
skate is offline
Old 06-27-2018 | 07:26 AM
  #220
Ron, My mistake. I fixed my post to thru hub, not over. Sam, your post helped me understand the sizes and attributes. Thanks guys!
Taboma is offline
