Go Back  Offshoreonly.com > Owners Forum > Sonic
496ho with a Whipple >
Old 06-08-2005 | 06:13 PM
jlsnyder26_Sonic's Avatar
Default Re: 496ho with a Whipple
Originally Posted by 26SONICBLASTER
jlsnyder26_Sonic,
I'm turning about 4900 rpm with the 22p 4 blade on my 26 Prowler. Thanks, Pete
Wow! Thats pretty low for a 22p prop if you have the 496 HO. I wish I had some good information to pass on, but all the Sonic's on our lake are 35 and up. I'm the only little guy. So, it's kind of hard to compare.
If you really want to go up in pitch, try looking for an old 24 Mach. They seem to have a little less stern lift which makes them a little more efficent than a bravo. I had great luck with one on my old baja. Stay away from the Hydro's, I hear they blow out pretty easy on a Sonic. Good luck with it and keep me posted on your findings. Very useful information
Cheers,
JL
BTW: Sorry guys for jacking your thread
jlsnyder26_Sonic is offline
Old 06-09-2005 | 11:53 AM
Thumbs up Re: 496ho with a Whipple
Thanks for the info JL. I appreciate it. Pete
26SONICBLASTER is offline
Old 06-09-2005 | 10:00 PM
Sonicblaster, I have a 2001 Prowler with a 502/415 HP, turns the 22" Bravo 1 5000 RPM with a speed of 63 MPH. When I run my 24" Bravo 1 RPM of 4700 with a speed of 63 MPH (better cruise speed,worse planing). Sounds just like my boat as far as performance. Steve
509 SC is offline
Old 06-09-2005 | 10:40 PM
Prowler's Avatar
Charter Member #1472
steve, i can't beleave it you said how fast your vessal is!what you gave up on trying to call me??horses,boat,very busy,but hay i've hadn't had to cut the lawn,the horses do that ,dave
Prowler is offline
Old 06-09-2005 | 10:49 PM
Prowler's Avatar
oh the daul ram external steering i put on steers earier now then it did before,very light on the steering wheel,before it was like it had very little assist,dave
Prowler is offline
Old 06-10-2005 | 08:36 AM
Steve,
Thanks for sharing your info on your 01' Prowler. I don't feel so bad now with my speed. Thought I would at least hit upper 60's with a 496 HO 425HP motor. Pete
Old 06-18-2005 | 11:23 PM
I have a 2001 26 Prowler with a 496 HO and a 24 4 blade. best I can do on the gps is 61. Any ideas? It is turning about 5050 rpm,s on the tach.
26 Prowler is offline
Old 06-19-2005 | 12:40 AM
I have a 260 with a 502 mag and 63 on gps is it. I am thinking about a whipple but I would need to upgrade the outdrive. Seems too expensive for a few mph
sonicator is offline
Old 06-19-2005 | 09:01 AM
Prowler's Avatar
well knock on wood, i've been running the same drive with a supercharger for about 5 years now,just don't hammer on it and change the drive oil often.dave
Prowler is offline
Old 06-19-2005 | 11:36 AM
Prowler's Avatar
a few mph,hmmmmm i added 20 something mph over you guy's,you don't know til ya try it.dave
Prowler is offline
