Go Back  Offshoreonly.com > Owners Forum > Sonic
Sonic 42 SS '96 >
Sonic 42 SS '96
Sonic 42 SS '96
Old 04-07-2008 | 04:54 PM
Elite Marine's Avatar
You have come to the right plac for help. These guys will get you all straightened out!!
If you need parts or anything, email us at [email protected] we have been shipping via UPS and Fedex overseas for a while, so its not an issue for us.
Nice boat!!!
Kirk
Elite Marine is offline
Old 04-07-2008 | 06:26 PM
45sonic's Avatar
A) http://www.offshoreonly.com/forums/s...d.php?t=183310
B) Prop holders
C) Two questions: Where does the hose go? And on the port side of the bow about the same area is there an outlet (drain opening)
45sonic is offline
Old 04-08-2008 | 08:07 AM
Lightbulb
B) Prop holders
Thank you for your reply!
About the hose ( Question "c")
1)The hose goes down into floor, we didn't have any chance to open it up. But we've checked all the system of hoses, and we didn't find the place this hose goes to.
2) As I remember there is no outlet (drain opening)
gozee is offline
Old 04-08-2008 | 08:40 AM
45sonic's Avatar
One or two possible answers. 1) There are two (actually three if you don't have A/C) storage compartments under the V-berth, it may be a drain for those compartments to the bilge (some of them liked to fill with water). 2) It may have been left there for an A/C install that was not done.
45sonic is offline
Old 04-08-2008 | 09:02 AM
Thumbs up
Thank you for your fast response. We will investigate this issue till end, I will post the results =)
gozee is offline
Old 04-08-2008 | 09:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Put an air hose into the end of it, and see if you can find where air might be getting expelled. Sonic used to lay up drain lines in the hull with the stringers that went from the bow to the bilge, and this could be one of them. If it is, there will be little opening or perhaps 1-2 inches of the same hose at the bottom of the forward bulkhead in the engine compartment. You will more than likely see your air coming out from this area.
Sydwayz is offline
Old 04-09-2008 | 08:03 AM
Thumbs up
Thank you Sydwayz, I will try it with air compressor.
gozee is offline
Old 04-11-2008 | 07:29 AM
Question
Hey guys,
Soon it's time to put the boat in water.
This weekend we have in plan to paint the bottom of the boat.
I have a question regarding the "water line".
There is no specification on water line measurements.
The only thing is that I see the dirty line on the body, which logically should be the water line.
Could you help me with that?
gozee is offline
Old 04-11-2008 | 08:31 AM
45sonic's Avatar
Best way if you really have to paint the bottom is put the boat in the water and either wait for a scum line to appear or mark the water line with a grease pencil.
45sonic is offline
Old 04-11-2008 | 09:50 AM
Thumbs up
Thank you very much for you support!!!
gozee is offline
