Go Back  Offshoreonly.com > Owners Forum > Sonic
31SS in MN, WI, or IA? >
Old 08-25-2008 | 08:31 PM
GO4BROKE's Avatar
If Hugh is willing to pick you up, thats better treatment than I got from a certain dealer in Chicago! Driving a new boat might be worth the price of a plane ticket. At least you will save the $90 I spent to use a rental for 3 hours.
But I'm not bitter!
[img][/img]
GO4BROKE is offline
Old 08-25-2008 | 09:26 PM
Jim Diesel's Avatar
"Unregistered Gun"
Originally Posted by Plum_Crazy
I know. But, I can't decide until I see if the Sonic cabin merits the speed loss.
31ss with blue motors you have the best of both worlds, luxury and speed. The new 32 Sunsation hulls produce great speed out of the black motors, I just think there a little cramped on room...
Jim Diesel is offline
Old 08-26-2008 | 08:12 AM
bigboat28's Avatar
Kjberman what motors do you have?
bigboat28 is offline
Old 08-26-2008 | 11:37 AM
Plum_Crazy's Avatar
What are you guys using to pull a 31SS with? How heavy is it with fuel on an aluminum trailer?
Plum_Crazy is offline
Old 08-26-2008 | 07:05 PM
GO4BROKE's Avatar
About 10K
Boat 7K
Fuel 1K
Trailer 2K
I towed with everything from a '78 1/2 ton (I wouldn't recommend it) to a couple of different duallies (definately recomend.)
[img][/img]
GO4BROKE is offline
Old 08-26-2008 | 09:26 PM
Jim Diesel's Avatar
"Unregistered Gun"
I first used a 00 Suburban 3/4t and pulled it fine, now a 04 Dirtymax (big difference)...
A board member named Z06 is using a modded 1/2t Z71.
Old 08-29-2008 | 07:58 AM
BigBoat - i have 496HO's but i run labbed 28 Bravo i's......seems to like that set up nicely.
kjberman is offline
Old 08-29-2008 | 08:00 AM
Default Towing 31ss
I use an 05' Expedition......and actually it tows pretty nice.....enough ppower, but more wheel base would be nice. Since i refuse to lose my A** on it i t will sit in my garage.
kjberman is offline
Old 08-30-2008 | 05:12 PM
Plum_Crazy's Avatar
I have a 3/4 ton Suburban. Since it's 4WD and has the 6.0L with 3.73:1 gears, it's only rated to tow 8,000lbs. Even though the 31SS on the trailer with fuel will be heavier than that, it sounds like I should be OK.
Old 08-31-2008 | 06:06 AM
hp500efi's Avatar
Member #9
06 HD2500 Duramax pulls very nice. On highway going 65, I can maintain 13mpg. If I get to 70, she drops to 11mpg.
Your 2500 Suburban will be fine. I would recommend replacing the Chevy hitch with a 10,000 pound rated hitch. I did and what a difference.
Member of the Liquid Jungle
hp500efi is offline
