Go Back  Offshoreonly.com > Owners Forum > Sonic
Finished Some Projects >
Old 03-02-2013 | 07:00 PM
  #91
Plum_Crazy's Avatar
There was one other little project this winter. I had to put a new trailer under the boat due to an axle failure on my Rocket. The 3rd axle came off the trailer at 70 MPH on the freeway when a weld on the mount cracked. So, I decided to go with a painted steel tandem 7K lb axle trailer with EOH brakes from Loadmaster.
Plum_Crazy is offline
Old 03-03-2013 | 07:11 AM
  #92
GO4BROKE's Avatar
Nice! Slick job on the speakers.
[img][/img]
GO4BROKE is offline
Old 07-17-2013 | 12:01 PM
  #93
Plum, enjoyed this thread. Are you still enjoying the electric trailer winch? I have heard good and bad about them but it would sure make life easier on my long suffering wife!
Don't you love the EOH brakes? One of the best things I ever did.
Dan
BajaDan is offline
Old 07-17-2013 | 01:27 PM
  #94
Plum_Crazy's Avatar
I actually moved my electric winch from my old trailer to the new one. It works great so long as you use the pulley block that comes with it(not pictured above). I ran a power wire from the battery of my truck to an outlet in the bed. I just plug in a 6' cable from the bed to the winch and power the boat on.
Yes, I'm lovin' the EOH brakes. I'll never own a trailer without them, now.
Old 07-18-2013 | 07:17 AM
  #95
Thanks for the feedback. I've been wanting to talk to someone that has done this. Do you use just the winch to pull the boat on the trailer or do you use it as an assist and power the boat up the trailer?
Dan
BajaDan is offline
Old 07-18-2013 | 08:39 AM
  #96
Plum_Crazy's Avatar
I walk the boat on and winch it. My local ramp is very steep. I've found that the v-block bow stop on the new trailer keeps me from getting the boat all the way on. So, I have to pull out and winch the boat another 6".
Old 07-18-2013 | 09:27 AM
  #97
Wow! Thanks. Must be a good winch. I must have one!
Dan
BajaDan is offline
Old 03-07-2014 | 11:57 AM
  #98
What model quick disconnects did you use for the speaker wire? I found all the other parts but those.
hanzcap is offline
Old 03-07-2014 | 01:38 PM
  #99
Plum_Crazy's Avatar
I purchased everything from markertek.com.
(2) Neutrik NL2MP Speakon Connector 2 Pole Panel Mount
(2) Neutrik NL2FC Speakon Connector 2 Pole Cable Mount - replaced by NL2FX
(2) Neutrik SCDX-9 Hinged cover - white
Old 03-11-2014 | 08:34 AM
  #100
thanks!
hanzcap is offline
Andy
Velocity
3
05-28-2008 09:32 AM
302Sport
Hustler
1
11-18-2007 08:13 PM
Tres
06-12-2004 06:55 AM
Tres
12-09-2003 03:07 PM
timucin
10-18-2002 04:20 AM
