No mufflers just turn-downs. A friend alos put them on his and lost the same rpm's with no mufflers.
Originally Posted by Plum_Crazy
(Post 3065412)
Since I've been doing nothing but maintenance projects on the boat all winter, I decided to get the drive/tab indicator bezel powdercoated to match the other bezels. This was a much bigger project than I expected. After disassembling the unit, I sent the bezel off to one of the major boat bling suppliers. They proceeded to lose track of it and then finally return it looking like total crap with lots of particles and bubbles in the PC. I ended up finding a local guy who could do the candy blue translucent color. He did an excellent job. Putting this sucker back together was the real trick while trying not to drop the spacers and spring-loaded pointers in the bottom of the hull. It was a lot of work for a little gain. But, I'm happy with the result.
Before: http://img.photobucket.com/albums/v2...sonic_dash.jpg After: http://img.photobucket.com/albums/v2...nic/bezel1.jpg http://img.photobucket.com/albums/v2...nic/bezel2.jpg |
Looks fantastic!
Originally Posted by GO4BROKE
(Post 3066848)
Looks fantastic!
Today I started the final maintenance project on the drives. I've never pulled drives before, but the drive jack-stand from the classifieds and an alignment tool made work easy. Everything looked really good. I'm also switching to Amsoil Severe Gear lube this season. http://img.photobucket.com/albums/v2...nic/drive1.jpg http://img.photobucket.com/albums/v2...nic/drive2.jpg |
After seeing the new-style Sonic logo Kyboy1020 recently installed on his boat, I decided to give my boat's name an update. The boat came with this name. While I liked the name, I never really liked the ampersand or the "G" in Gin. Sonic was kind enough to provide the printer with the electronic artwork necessary to bring the name up to date. Thanks, Sonic!
Old: http://img.photobucket.com/albums/v2...Sonic/logo.jpg New: http://img.photobucket.com/albums/v2...blue_sonic.jpg |
Good job, agreed the new looks better!
Plum Crazy boat looks real good very clean I like the upgrades and pro net I think is a great Idea Im going to do the same I see they got some 49 3/4 long and 55 1/2 witch one did you use I would like to use the 49 3/4 if it would work because the hieght is shorter
I'm pretty sure I used the mid-sized 55-1/2" net to make sure the net was fully inside the wall.
I've wanted to upgrade the stereo since I bought the boat and finally finished today. I used a JL Audio M600/6 amp and a total of 9 JL audio speakers. There are two 6.5" in the cabin. Then, there are six 7.7" and a single 10" sub in the cockpit. The stereo unit is a Fusion that docks an i-Pod internally. It's all controlled by a remote on the dash, so the wife can play DJ. The sound is amazing! I also really like the 3 zones. I can control the cabin, the sub, and the cockpit volume all individually.
Link to pics |
Looks Great!!!
| All times are GMT -5. The time now is 06:21 PM. |
