Go Back  Offshoreonly.com > Owners Forum > Sonic
trim master trim tabs fixed by me with photos >
Old 07-03-2009 | 12:40 AM
Default trim master trim tabs fixed by me with photos
Hi guys
here is few photos how i fixed my leaking actuator
on this photo u can see one leaky cylinder
and on this photo fix icylinder in wise to undo front nut using it just multi grip .
make sure do not over do it after all it is just plastic
and this is what is in side of cylinder
On this photo u can see two set of seals . Top ones are old ones and new ones are below
and here is piston with new seals
to fit them on just push it with fingers
now just putt all together and fit cylinder back on boat
top up oil and just bleed them by operating up and down few times thay are self bleeding
and here is one fix cylinder like brand new all work takes around 20 min. I hope this will help to someone one day
cheers noluck71
noluck71 is offline
Old 07-03-2009 | 03:24 PM
26sonic's Avatar
yes that is great info !!!
26sonic is offline
Old 09-12-2013 | 07:51 AM
Smile new seals, where?
Hi noluck71!
I'm just doing the same with my trim master trim tabs.
But I have truble to find new seals. Do You remeber were You got the seals from?
Gratful for answer
/P Tegenfeldt, Falun, Sweden
Tegenfeldt is offline
Old 06-03-2014 | 09:42 AM
I just got them from local seal store which is just 10 min away from my place
can not remember but cost me les than $10
http://www.sealimports.com.au/contacts.html
noluck71 is offline
