Go Back  Offshoreonly.com > Owners Forum > Sonic
fuel tanks on 31SS >
fuel tanks on 31SS
fuel tanks on 31SS
Old 08-31-2009 | 06:34 PM
Default fuel tanks on 31SS
Ok guys, has anyone accessed the fuel tanks on a 31SS? Do you just unscrew the screws in the floor, cut the silicone and pick them up?
Something is wrong with the port side fuel pickup where it goes into the switch valve and I need to replace it.
Anyone have any helpful hints, tips, or tricks?
niceguy is offline
Old 09-01-2009 | 05:33 PM
Ok, well I guess I'll just dive in head first and report back.
niceguy is offline
Old 09-01-2009 | 07:16 PM
GO4BROKE's Avatar
I don't know about pulling up the floor. My 31 had pirelli on the sole. It also had an access hatch to get at the fuel senders. It was located under the back seat.
[img][/img]
GO4BROKE is offline
Old 09-02-2009 | 06:14 AM
Man that would be ideal. I'll check it this weekend. Thanks.
niceguy is offline
Old 09-03-2009 | 11:25 PM
Mine seems to have a similar problem I plan on getting rid of the switch and just pulling off both tanks all the time... It would be nice if I had time to replace my fuel pressure regulators to
FuelinAround is offline
Old 09-08-2009 | 07:46 AM
There is an access panel under the rear seat. To get to the tanks themselves you have to remove the bolsters, the rear bench, unscrew the floor, cut the silicone and lift. I had to cut the rear bulkead to get the tanks out.
Pure Energy is offline
Old 09-08-2009 | 07:59 AM
As long as I can get to the senders, I think I can fix my issue there. I did check yesterday and found the access hole.
niceguy is offline
