Go Back  Offshoreonly.com > Owners Forum > Sonic
36ss info needed >
36ss info needed
36ss info needed
Old 11-01-2010 | 06:28 PM
Default 36ss info needed
anyone have any info on this 36ss .
whats the difference between this and a 358 ?
http://www.boattrader.com/listing/20...SS-36-97534571
thank's
mike
mikebrls is offline
Old 11-01-2010 | 06:59 PM
thank's
mike
I don't have any info on it but it is a 358
andyt25 is offline
Old 11-01-2010 | 07:08 PM
That boat is at my marina. I was never on it, but it looks very clean, and appears to be well maintained. The owner washed and flushed after every run. I never seen him have any issues with. I will be heading back there soon, is there anything in particular you need to know, I can check for you.
Hope that helped!
Murf
murf is offline
Old 11-01-2010 | 07:24 PM
im waiting to hear back from the broker .
one thing is that the engine have ben rebuilt by who dont know yet but the thing that sound's a bit crazy is that there saying the motor's have 675 hp each and there rebuilt 500efi's sound's like a lot of power for a 502 ci motor and then they said there running 28 pitch 4 blade prop's that sound to small to run the 90 mph they claim but i dont know what gear ratio is in the drive if that would make a big difrence with all the stuff said above ,
what's your thought's
thank's
mike
mikebrls is offline
Old 11-01-2010 | 07:59 PM
t500hps's Avatar
21 and 42 footers
FYI: I built a set of 500efi's into 540's.......these do have monoblade TB's like mine but that plenum just can't handle the airflow. My 540's, cam, heads, 9.75 compression only made 630hp (5,200) but did pull 700tq (4,300). A different cam and spinning them higher would have netted a little more but at the expense of TQ.
t500hps is offline
Old 11-02-2010 | 07:42 PM
That boat would not run 80 the way it sits now. Eddie young is getting to do mine. With the intake system on the boat now it will not make that kind of power.
45SS is offline
Old 11-02-2010 | 08:31 PM
i thought the power and the speed was on the overkill side from there add
thank's
mike
mikebrls is offline
Old 11-03-2010 | 05:04 PM
My 02 358 with stock 500efi's had 28's with 150 gears.
Sonic Steve is offline
Old 11-03-2010 | 05:53 PM
and what kind of top speed did u have .
there claiming 90 mph but that seem's to high with 28 pitch prop's may if it had some 32 pitch 4 blade it would run 90 .
im not sure thow so i will take as much info as i can
thank you
mike
mikebrls is offline
Old 11-03-2010 | 07:25 PM
I'm pretty sure a 31ss with 500s runs 83-84 tops so 90 in a 358 sounds pretty high
andyt25 is offline
