Go Back  Offshoreonly.com > Owners Forum > Sonic
Salt-Away? >
Salt-Away?
Salt-Away?
Old 02-13-2011 | 05:55 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I run the boat for a couple minutes on the hose. Then shut off the water, and drain maybe 4 feet of the garden hose. Fill the hose up with Dawn and connect it back up to the flush fitting. Turn on water and immediately start engine. Run it again until you have no suds coming out.
Sydwayz is offline
Old 02-13-2011 | 06:11 PM
jfm
Have you ever opened up an engine that you have done this to? I would be curious to see the difference between a salt away and dawn.
jfm is offline
Old 02-13-2011 | 06:14 PM
OldSchool's Avatar
Originally Posted by Sydwayz
Do some digging on here. Many feel it has been detrimental to their headers. "BillR" is one of those folks.
I use Dawn.
It was heads and I believe that he's now found out that it was the ole engine builder switcharoo. Just a guess.
Salt Away..... I use it after every time that my boat is run. It works very well.
OldSchool is offline
