Go Back  Offshoreonly.com > Owners Forum > Sonic
Bolster mounting... >
Bolster mounting...
Bolster mounting...
Old 03-24-2003 | 10:33 AM
Sydwayz's Avatar
Forum Regulator
Default Bolster mounting...
Can anyone tell me... My 1999 26' Prowler; is the bolster mounting hardware to the floor comprised of thru bolts with nuts, or are they just screwed to the floor?
aTdHvAaNnKcSe !
Sydwayz is offline
Old 03-24-2003 | 03:00 PM
45sonic's Avatar
Brian,
Usually screwed into the floor. Sometime they did through bolt them but not all the time. If it is bolted through it will be a real pain to remove the bolts. Are you trying to remove the seats??
Bill
45sonic is offline
Old 03-24-2003 | 04:26 PM
Brian,
I just finished removing the bolster on my 42 to change out the carpet and it was screwed to the floor but the side of the seat was bolted through.
Sonic Steve is offline
Old 03-24-2003 | 09:49 PM
Sydwayz's Avatar
Forum Regulator
Thanks guys. I am making heavy paper patterns for new 40 oz. carpeting that covers more than the factory carpet. Going around the posts is a pain. My plan is to un-screw them from the floor, and support them from above, up about an inch, by laying a pipe across the top of the grab-rails, and bungee the weight of the bolsters up off the floor for a little bit. Thanks again!
Sydwayz is offline
Old 03-25-2003 | 08:47 PM
GO4BROKE's Avatar
Take 'em out dude, undoing a few more fasteners will be less hassle than all those gymnastics!
[img][/img]
GO4BROKE is offline
Old 03-25-2003 | 10:17 PM
Sydwayz's Avatar
Forum Regulator
Ya, gymnastics one way or another. You have to get upside down in them gunwale compartments to get the nuts off the side bolts. I will figure something out. Thanks!
Can't wait to get 'jiggy' on the new carpet.
Sydwayz is offline
Old 04-30-2003 | 10:03 PM
blown formula's Avatar
Of course, you could do it my way! Put in a 6" inspection port in the floor, drill bolt holes and install (from the back side thru the inspection port) stainless T-nuts and use stainless allen cap screws in the bolster leg. The carpet covers the inspection plate. I have had screws come out
blown formula is offline
klaw
2
04-08-2008 10:16 AM
Coolerman
4
05-13-2005 07:26 PM
Panic Button
1
04-29-2005 06:27 AM
wowchad
2
01-11-2005 05:04 AM
fishead
1
01-13-2003 06:28 AM
