Go Back  Offshoreonly.com > Owners Forum > Sonic
The "Blown Formula" Sonic Project  !! >
Old 04-29-2003 | 04:19 PM
blown formula's Avatar
Custome made diamond plate trim & tab pump brackets w/ 80 amp main fuse block & solenoids attached. Removable as a single unit by removing two bolts (and of course the hoses & battery connections!). Holley fuel pump, regulator, fuel tank switch selector & fuel filters to the left and also painted purple to match. I forgot to mention, all the pumps were diassembled, cleaned, flushed, new filter screens & gaskets were installed & all new solenoids.
Attached Thumbnails The "Blown Formula" Sonic Project  !!-starboard-pumps.jpg
blown formula is offline
Old 04-29-2003 | 04:26 PM
Port side (reflection of starboard side)
Old 04-29-2003 | 04:30 PM
Port side trim & tabs pumps- reflection of the starboard side. Notice the pump mounting reversal as dictated by the side of the boat mounted on.
Old 04-29-2003 | 04:36 PM
All trim, tab, fuel pumps, regulators, tank swtches & filters mounted to the seat base now. Notice the "faded" purple to yellow paint on the hatch lift mechanism. Matches the paint theme on the bow. Disassembled the lift, cleaned, greased and reassembled. Works like new!
Old 04-29-2003 | 04:42 PM
Here you see the flush valves (yellow) that shut off the hull water pickups when running on the hose. Neat!. Supplies the sea pump only, no water overboard thru the pickups.
Old 04-29-2003 | 04:46 PM
New (2000) gimbal assy to replace the original one. New tab & trim cables & trim cylinders.
Attached Thumbnails The "Blown Formula" Sonic Project  !!-new-gimbal-assy.jpg
Old 04-29-2003 | 04:51 PM
Clean & white to the deepest recesses of the hull. Clean enough Fred?
Attached Thumbnails The "Blown Formula" Sonic Project  !!-deepest-recesses.jpg
Old 04-29-2003 | 04:59 PM
Back to the front now. The re-upholstered drop out bolsters.
And the new tilt hydraulic helm.
Old 04-29-2003 | 05:06 PM
The "new" rebuilt trim indicator with red pointers, new led back lighting & new springs. Now powder coated.
Old 04-29-2003 | 05:12 PM
New Depth gauge. Remember Fred, the old one was stuffed into another old gauge housing so it would fit the 3 1/4" hole? Custom plug and flashing to mount gauge.
Attached Thumbnails The "Blown Formula" Sonic Project  !!-new-depth-gauge.jpg
