Go Back  Offshoreonly.com > Owners Forum > Sonic
Speaker placements in a 31SS >
Old 03-30-2004 | 09:03 PM
Scott Morehead
Thanks for the info...
I'm am looking into doing the same kind of upgrades this spring. Would love to have all the ideas possible, before I go cutting holes in the fiberglass. Where to postion the subwoofers has def. been my biggest problem. Having a special box built to install in one of the port or starboard storage areas with the sliding doors seems to be the option most suggest to me by the installers. Finding a well ventillated yet dry area to place the power is also a problem. I have AC so not much room under the sink.
Thanks for the ideas,
Scott
Old 03-30-2004 | 09:55 PM
ST31's Avatar
I am wondering if the 10" bazooka tube that I have will fit into one of the port or starboard storage areas. Has anyone else done this?
ST31 is offline
Old 03-31-2004 | 04:15 PM
shewbart's Avatar
I installed 2 10" autobaun subs under the rear seat and it was very tight because of the 4 battery set up I have for the power inverter there is room for another sub in the middle if you remove the cockpit light and since I have added a neon tube just above the light it does not matter to me by the way I also added the neon in the vents on the side of the boat, looks pretty cool at night. My highs are the same as jlsnyder but I want to point out my jl audio 500 for the subs is already out and my buddy has replaced 3 of them is it the vibration, salt air moisure of the fact it is in the first compartment with my power inverter and shares a wall with the cooler? I have noticed condensation on the amp in cold weather when the cooler is full of beer and ice?? Sounds good when it all works.
Good luck!
Rent money II
shewbart is offline
Plum_Crazy
Sonic
42
10-01-2008 09:36 AM
Jpm540
Sonic
3
07-28-2007 07:20 PM
challenger
Sonic
4
04-16-2005 07:52 AM
krakmeup
Superboat
9
01-20-2005 05:03 PM
HiPerf2000
Sonic
1
03-10-2003 02:57 PM
