Go Back  Offshoreonly.com > Owners Forum > Sonic
How to tighten shift cables >
Old 05-23-2004 | 08:04 AM
Default How to tighten shift cables
Have a 358 and when I cruise the star. throttle always like to back off.
I checked the throttle bodies and they seem the same. Is there a adjustment to tighten throttle cables that I am missing? I pulled the shifters up and couldn't
find a adjustment.
roadrunner is offline
Old 05-23-2004 | 08:42 PM
GO4BROKE's Avatar
Default Re: How to tighten shift cables
What type of sticks do you have? There should be a tension adjustment at the shifters.
[img][/img]
GO4BROKE is offline
Old 05-23-2004 | 08:43 PM
GO4BROKE's Avatar
[img][/img]
GO4BROKE is offline
Old 05-24-2004 | 06:52 AM
splashandburn's Avatar
I had the same problem you did and called Gaffrig. If stand at the helm and look inside the rubber boot of the shifters you will see an allen screw. Just give this screw a little turn and this will increase the tension on the throttle.
splashandburn is offline
Old 05-24-2004 | 05:08 PM
Thanks for the help .I will give it a try.At least now I know my throttle bodies are even!
Old 05-24-2004 | 09:14 PM
GO4BROKE The sticks are quicksilver zero effort control
I pulled the rubber up on shifter and could not find a allen adjustment screw
have any ideas?
Old 05-25-2004 | 06:50 PM
GO4BROKE's Avatar
I'll go look at mine and see what I find. I'll post tomorrow.
[img][/img]
GO4BROKE is offline
kennyo
06-12-2008 08:07 PM
YOLO
05-23-2008 12:43 PM
phebus
13
05-01-2007 07:33 AM
Perfectmix
6
05-02-2006 06:38 AM
HiPerf2000
Sonic
2
04-22-2004 08:06 AM
