Headliner Problems
Hey Sonic 28, how did you keep the headliner from falling back off after you glued it up and before the glue set? Stretching it and ensuring no wrinkles must have been a big headache. Congratulations on getting it done, not an easy task!
with the foam back you use adhesive on the foam and on the fiberglass.let both dry then apply make sure you start in the center then work one side at a time. i forgot to mention when you guy makes the new headliner have him leave an extra 4-6'' on the sides it will help.then trim.
