31 and 42 Sonic bridge clearance height above water
Max Height of 31 and 42 Sonic above water when sitting in it please, arch and no arch. This assumes ducking your head without the arch. <gg>
My 31 had the 2" taller windscreen (no arch) and measured just under 5' - plus or minus an inch. The amount of water and fuel really didn't affect this height. Hope this helps.
i may be able to get you an approx waterline to arch measurement this weekend. boat is on the rack, so it wont be exact, but should be close.
it is a 35. let me know if you still need it.
Don't hurt yourself HIPerf2000, no climbing up the outside of the rack! If it is easy and safe to do, yes, I'd like the height from the waterline. I am guessing a 42 is not going to be much different, and the 31 is going to be less (what I have).
THKS!
THKS!
CBR,
My 358 has the 2" taller windscreeen and I would guess it is approx 5'6" from the water line to the top of the screen. I was able to get the nose under a 5' bridge but the windscreen wouldn't clear it. Hope this helps.
