1" Imco Lowers On A 32 Dominator
Took a test run today, 1" imco lowers and p5x 30" labbed, increased speed to gps 94mph, but was on the edge. very hard to control unless i have to get used to that unstable feeling. has anyone tried this ? It might be the props, next run i will try my 6 blade herrings. what props are you guys running?
05 32 non SS Dominator
496 HOs
Raised X Dimension when built from Sunsation
Best Ever 86.4 GPS
Bravo 1 4 blade Labbed 32 which becomes a 31 pitch
5000 rpm
Also had a set of 29 pitch Bravo 1s
Bumped the **** out of rev limiters a solid 84.2 gps Everyday
496 HOs
Best Ever 86.4 GPS
5000 rpm
Right side serial # K 0 4 1 4 5 0
Left side serial # K 0 4 1 4 5 1
call them direct and have them make you a set and you will save all that prop testing work,
These props are not only labbed 32's for the dom hull with the 496 HO's but they are tweeked special for our hull with the raised X. If you do not have the raised X they work good also. I ran them all last season with a 2 mph gain over my 29s
Have fun
