Go Back  Offshoreonly.com > Owners Forum > Sunsation
Fastest single 32 >
Fastest single 32
Fastest single 32
Old 06-29-2007 | 09:51 AM
Originally Posted by Chris288
If your drive is a 1.5:1 there is no possible way your running 81 @ 5,100.. That puts your prop slip at 3.24%.. A 1.36 puts your slip at 12.27 which makes more sense..
Exactly, and if its a stock bravo prop you should actuallt use a pitch lower then what it is to do the calculations because of the way they are measured. That would put his slip with a 1.5 drive at better then 0.
The internals were probably changed, you shouls be able to check by counting the rotations of the prop when you turn the shaft.
dagah2x is offline
Brian N
01-14-2020 06:25 AM
chief fever
Grand Lake/LOTO/E-Dock
8
01-12-2020 11:35 AM
Elite Marine
28
10-19-2007 08:36 AM
rackster
Fountain
33
01-16-2007 11:06 PM
Steve_H
07-17-2003 06:15 PM
