Go Back  Offshoreonly.com > Owners Forum > Sunsation
HELP!! Sunsation Dominator 32 Twin 502EFI >
Old 08-05-2020 | 05:33 AM
Originally Posted by blownhammer2000
What rpm are you seeing. If your efficiently spinning those 30's with the 500efi's you should be mid 80's for sure
5100 rpm and if i try to trim it a bit more front starts bouncing
Shawnr is offline
Old 08-05-2020 | 07:28 AM
Knot 4 Me's Avatar
Where do you run the boat? Low 80’s is about right for an everyday speed for that boat. Mid-80’s would be a perfect weather, light load, perfect water conditions speed assuming motors are still strong.
Knot 4 Me is offline
Old 08-05-2020 | 07:38 AM
on a rivers in canada , i just figured eith 2x 496 ho guys are runing 84 mph and with 2x 502 blue barely over 80
Shawnr is offline
Old 08-05-2020 | 07:55 AM
F-2 Speedy's Avatar
you start a post saying you have 502 efi's now there 502 blue motors, no such thing as a 502 blue engine, 500 hp, 500 EFI and 525 triple nickle. but there all 502 cu inch
F-2 Speedy is offline
Are the 496 guys the stepped hulls? I've been on a 496 HO stepped hull 2006 and yeah mid-80s are possible under very right conditions.
Captain YARRR is offline
Old 08-05-2020 | 10:14 AM
Mentalpause's Avatar
I was thinking the same thing. I don't think 496HOs on the older dominator hulls (which were my favorites) would do mid 80s with normal loads and normal conditions. My 2000 dominator with 454 mags, 385hp ran 75-76 at LOTO all day long. I ran labbed 28s on it. It never liked the last few ticks of trim. It would always bounce the nose, start to chine walk and slow the boat down 1-2mph.
Mentalpause is offline
Old 08-05-2020 | 11:25 AM
yes they are 2008 so maybe the new hulls like you are saying are way better
Shawnr is offline
Old 08-05-2020 | 11:27 AM
500 then it is blue motor s mercury
Shawnr is offline
Old 08-05-2020 | 11:28 AM
The newer hulls are stepped hulls. Your 2002 is a straight hull with a pad.
Old 08-05-2020 | 11:33 AM
okay cool so the hook i see toward the back of the hull is not a step ??
Shawnr is offline
