HELP!! Sunsation Dominator 32 Twin 502EFI
No. I think they call it something like laminar flow interupter. It's only for turning. If you look at the hull it is not a full step across the entire bottom. I believe the newer hulls have that plus 2 full steps aft the flow interupter.
okay cool , so what s next for me to go faster , superchargers or put some -2 drives ?
The older 32's do have the Vortex setup midway down the hull but has others have said it is not a step. There is hook built into the bottom of the boat 6" or so from the transom if I recall correctly.
The 2008 and newer 32's with the full step (New hull design) run 82 - 84 if I recall correctly with 496 Mag HO's and 32 Pitch Bravo's. My 2003 32' with HP500's ran 90 MPH on GPS with labbed 30's. They had different intakes etc. but were very close to stock, I had a completely different setup than you though, I had ITS boxes with -2 shorties. I don't know if you will find concrete info. showing whether anyone with your setup trying shorties and having success. Some have tried just not sure if you will find any info. on it, I do know that Wayne had the X Dimension dialed in on them from the factory.
and what exact drive did you have on ?
