Go Back  Offshoreonly.com > Race Talk > Super Boat International
New Vee Bottom Rules >
Old 05-15-2007 | 08:14 PM
  #141
It will be an awesome sight in Sarasota to see 12-15 (maybe as many as 20) Vee boats lined for the Start.
Just like the good 'ol days when we all raced together in Sarasota.
Awww yes....the Mecca of Offshore Powerboat Racing.
Lisa...put down you poker hand and come on out and play...Its OK...you don't have to have a top on when you race with us.
KenD is offline
Old 05-15-2007 | 09:14 PM
  #142
THEJOKER's Avatar
Originally Posted by BAD APPLE
I'm going to run the race boat that Friday w/ Hollis throttling in the Poker run before the race.
Brett
Ole buddy ole pal!
THEJOKER is offline
Old 05-15-2007 | 11:03 PM
  #143
shifter's Avatar
www.weismann.net
Where does the bravo, 1.50 and a 525 fit into what we do? Ask John if we can run a 1/4 canopy boat in SV. It seems like P2 doesn't exist anymore for what we wanted, maybe I can get the rules in SV to change back to pre 2003.
Mid season changes are great.
pat W
shifter is offline
Old 05-15-2007 | 11:46 PM
  #144
Pat,
Where have you been?
Enclosed canopies have not been required, but "highly recommended" in Super V for quite some time.
You have always had a place...its has been up to you to find it.
You need to read the rules again....carefully.
Under the new format it will be a lot safer than before if you want to race competitively in a non-canopy boat.
What final gear ratios do you offer? There isn't any info on your web site about the technical specifications of your drive.
We are trying to keep you afloat...but you need to start kicking your feet or something.
Best regards,
Ken
KenD is offline
Old 05-16-2007 | 07:22 AM
  #145
TeamTaboo's Avatar
TeamTaboo
Ken will my Fountain with the ASD8's work in this class. Top speed so far has been 106, we have a 1:57 gear.
We where going to put big motors in it for unlimited but this mite work for us. Bill
TeamTaboo is offline
Old 05-16-2007 | 08:19 AM
  #146
Bill,
1:57 gears?
Arneson web site shows 1.53:1 as stock.
Are you stock?
Ken
KenD is offline
Old 05-16-2007 | 09:17 AM
  #147
TeamTaboo's Avatar
TeamTaboo
Ken all I know is that Mark Wilson said we had 1:57 gears. I would have to take it apart to check. Arneson are 1 to 1 ratio the ZF gearbox has the ratio in it. When we started this that is the closest we could get to 1:61, the next gear down would be in somewhere in the 1:35 range. Let me know, it will be easy to put it back together to run Sarasota or Washington. Sarasota may be tough with so many super cat races.
Old 05-16-2007 | 09:37 AM
  #148
Bill,
Maybe I'm not reading it right.
I was refering to this:
File Type: pdf
KenD is offline
Old 05-16-2007 | 09:56 AM
  #149
TeamTaboo's Avatar
TeamTaboo
Ken I think whose are the Arneson's that bolt on to a Mercury drive. Ours have the strait Arneson shafts with a gearbox
I just found out that there are only two gear ratios for our ZF trany they are 1:41 or 1:57. The 1:57's gave us the best speed at 105.8 and the 1:41's gave us way to much excelleration but only 99mph.
Old 05-16-2007 | 10:12 AM
  #150
Bill,
Thanks for the info.
I have some other questions. I will PM you.
It will be great to see you again in Sarasota.
Ken
KenD is offline
