-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   Faster (https://www.offshoreonly.com/forums/superboat/112740-faster.html)
FASTERDAMITT 09-28-2005 11:11 PM
Re: Faster
That's wierd the way the damage is a mirror of the other on the gears. Looks like the shaft bent or failed.
articfriends 09-29-2005 01:22 AM
Re: Faster
I sheared off a max worxx vert shaft last time it broke so the shafts and gears were new at the same time. I think one tooth starts to chip away then it starts to take out the one next to it. I started seeing metal on the magnets after 45 hours. Pure and simple the high load and torque tears these bravo based drives up when you start putting serious tq to them. My motor makes 850 ftlbs of tq from 3200 past 5600 and peaks at 960 plus ft lbs,my boat pushes thru the water like a brick,somethings going to give sooner or later.I started looking at these super boat singles about 6 weeks ago,they are intriguing,I wonder how fast one would go with my motor in it? I see low 90's in my 272 baja with my power,Smitty
Pat McPherson 09-29-2005 08:04 AM
Re: Faster
Well, Faster hit 94 with 800HP and has not dialed her in yet... :D
With another 150, triple digits without question... :evilb:
FASTERDAMITT 09-29-2005 12:03 PM
Re: Faster
What's a 272 Baja weigh?
articfriends 09-29-2005 04:10 PM
Re: Faster
4400 plus fuel and accesorys,Smitty
