-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   Headers in a 24 (https://www.offshoreonly.com/forums/superboat/114568-headers-24-a.html)
t-islands 10-17-2005 03:28 PM
Headers in a 24
Can anyone tell me if CMI headers on a 496 will fit under the hatch on a 24? I am hearing that they at 3/4" taller that the stock exhaust.
If that is true, I will have a clearance problem...
Any other header suggestions?
Raylar 10-17-2005 03:58 PM
Re: Headers in a 24
Check with Fred at Trick here on OSO. He is a dealer who has sold several of the new CMI -496 kits . I would think he could give you the exact dimensions and specs.
Best Regrads,
Ray @ Raylar
Dave M 10-17-2005 04:06 PM
Re: Headers in a 24
Hey t-islands,
I think you and I are the only people who have 24's with a 496. I had to raise my hatch just to fit the 496. I heard that the CMI kit comes with 3" spacers for the plastic motor cover. I was thinking about the headers too. I'm still rethinking the hatch issue. I think it's going to have to be raised more. I can only go up another inch before the hatch is flush with the gunnels WITHOUT the cushion. I'm thinking of talking to a fiberglass guy to see what my options are. I'll snap some pics tomorrow to show the mods I made.
Dave
t-islands 10-17-2005 05:57 PM
Re: Headers in a 24
Best Regrads,
Ray @ Raylar
Ray, I talked to Fred, that’s where I got the 3/4" detail. I wanted to be sure I wasn't missing something. My measuring was not very accurate.
t-islands 10-17-2005 06:04 PM
Re: Headers in a 24
Originally Posted by Dave M
Hey t-islands,
Dave
Dave, You must have kept the engine cover. I removed mine and everything fit with our raising the hatch. It's very close.
I am also considering raising the hatch; but I want to be real sure on the height before I make any mods. I would be real interested in what you did.
Tim
Dave M 10-17-2005 06:21 PM
Re: Headers in a 24
3 Attachment(s)
I bolted 2x2 x .25" aluminum angle on each side (pic1)
I inverted the hinge and drilled a whole for it to come out from underneath. (pic3)
If you notice in pic2, the hatch is nearly flush with the gunnels. This also created a gap between the seat back and seat bottom. I screwed a 2x2 to the bottom of the seat to make up the difference. I also but a piece of lexan between the seat back and the hatch. I was afraid that my kids would be able to stick their hands in there and get caught in the motor.
I had to trim about 2" off the plastic cover in the very front.
Dave M 10-17-2005 06:25 PM
Re: Headers in a 24
1 Attachment(s)
You can see the piece of lexan in this pic. This winter I'll probably get the seat back redone with another section of cushion that will cover the gap. I can then take the 2x2 off the bottom of the seat.
You change one little thing and it starts a ripple effect with the whole interior!
t-islands 10-17-2005 06:59 PM
Re: Headers in a 24
Dave,
Looks good. How much did you actually raise the hatch? All I need is 1 inch.
Fred also told me the top of the header is farther forward than the stock tubes. I might be able to use that to my advantage. I would really like to take some measurements off an installed set.
Dave M 10-17-2005 07:38 PM
Re: Headers in a 24
I raised the hatch 2-3". Check out this thread....
http://www.offshoreonly.com/forums/s...ht=496+headers
There are some pics of the CMIs installed in a Velocity.
Dave M 10-21-2005 06:42 AM
Re: Headers in a 24
Hey Tim,
Did you order those CMI's yet? :evilb:
