-   Superboat (https://www.offshoreonly.com/forums/superboat-44/)
-   -   730+ HP smallblock (https://www.offshoreonly.com/forums/superboat/120301-730-hp-smallblock.html)
TeamSaris 01-13-2006 02:22 PM
Re: 730+ HP smallblock
I wonder what prop you would run?
Dregsz 01-14-2006 01:50 AM
Biggie does a 434 CI Small Block Marine motor, 10:1, pump gas, Solid Roller cam, 600 HP on the Dyno sheet, 6000 RPM redline.
doesn't rev like the one in the vid, but
It's a boat motor
HuntingtonBeach 01-27-2006 11:54 AM
Pretty sick you can rev a SB that high... Be like having a Nascar motor in your boat!!!
Pat McPherson 01-27-2006 12:25 PM
Rob,
I'm by no means an engine expert, but this is my take on performance marine engines for pleasure boats.
For a naturally aspirated engines 1.1-1.2HP per cube tops. More than that the idle quality and reliability is going to be poor.
If you want a 500+HP small block for a boat, their are two choices. Supercharged or high dollar tall deck engine...
Dregsz 01-27-2006 12:26 PM
You can rev big blocks really high too. people think the shouldn't for some reason, but big blocks love to rev.
You aren't gonna do it in a boat though, the limiting factor on rpms in boats is drive breakage above 6000 rpm and cam selection which is all bottom end torqure. high reving car motors have no bottom end. they are built to run with a higher rpm range, say 3500-9000 rpm. they won't likely idle at 750 rpm and would stall trying to shift into gear or break the drive tranny shifting into gear w a high idle
Dregsz 01-27-2006 04:32 PM
My advice is pass on the SBCs mount a BIG BLOCK,
even big cube sbcs, just say no.
HuntingtonBeach 01-27-2006 08:02 PM
Can't use BB they wont fit unless you give up all the cockpit... With the Y2K being so lite I would think you could sacrafice some torq for more mid-high power?
lightspeed 01-27-2006 09:20 PM
We Had A Pair Of ZUL Motors In ARMED AND DANGEROUS 372 Ci 750 HP Reved At 7500 What A Sound Stellings Into A Y Pipe Unbeliveable Those Motors Pushed a 32 Mirage With Crash Boxes And #3s At 100 +
z.zuperboat 02-02-2006 12:45 PM
John That Is My Favorite Boat Of All Times. Lattona And Scrow Made It Look Like A Ride To Kismet. Zul Made 750hp With A 372 And That Was 15 Years Ago. Some Builder Cant Match His Talent 15 Years Later. What Can Build Today.
Dregsz 02-02-2006 01:39 PM
A big block is like 2"s longer then a small block.
It won't fit?
