Oil/Drive changes ???
I run 15-50 Mobil 1 synthetic in my engine. At 20-25hours I change the filter and top off. Then at about 35hours I change the oil and filter...
As for the drive, I run the Merc HP synthetic and change it at about 50hours...
Gary, if I had your engine and drive package, I'd run synthetic and change everything, every 25hours...
Patrick
Patrick
I Use Penzoil Racing 25-50 And Would Love To Change Every 50 Hours. But I Only Average 10 Hrs A Year So 10 Hours It Is. For The Drive I Use Amsoil. Dont Know If I Would Use It In A Bravo.
I changed the oil and filter at 20hrs.
Changed the drive oil at 35hrs. I would have done that earlier if I had the boat on the trailer more often.
I agree with pat, w/ your HP package its good preventative maintenance.
BTW, don't forget to check on the hydraulic steering fluid too.
I change every 20-25 hours which usually means 3x a season. Oil is synthetic but I forget which one (its at the shop)... current boat is a V-drive so no outdrive but the tranny for the V gets changes the same as the engine.
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
jeff32
06-28-2006 08:48 AM
Velocity Tom
07-16-2003 10:13 AM
