-   Sutphen (https://www.offshoreonly.com/forums/sutphen-64/)
-   -   26' Sutphen (https://www.offshoreonly.com/forums/sutphen/30320-26-sutphen.html)
ChristianGott 09-21-2002 02:05 PM
26' Sutphen
1 Attachment(s)
I have re-attempted a more efficient response. The 26 is a great ride. With a little up dating(Gaffrig throttles, Revolution 4 props) the boat has a better than new attitude. The reason for the switch to 4 blades was exactly as mentioned, not enough stern lift. The matched set of 350's weigh in at quite a bit. The Revolutions are Merc. approved for the Alphas, so it was a great match. I picked up almost 8 mph at 3100 rpm (52ish cruise), and planing time was reduced dramatically. I still don't have a true top speed, still trying to dial it in. Hopefully the attached picture loaded. I have a larger file if you would like it emailed to you. Thanks.
floatingphil 09-23-2002 08:46 AM
Christian,
What props were you using before, that you were able to pick up so much midrange speed? Are you using the 23"?
ChristianGott 09-23-2002 03:55 PM
I picked up the boat with 21x3's, the motors would spin to almost 5100rpm. Way too high. I should be down around 4600, so by adding a blade and going up to 23x4's the rpms came down to the 4500 range. I'm sure you're aware of all the considerations when prop shopping. I wanted stern lift, better hole shot and a higher cruising speed. The boat now has a much more balanced feel to it. I'm sure that, too, helped the cruising speed. I can't wait for the "perfect" day to see what the top end is.
fobes 09-24-2002 05:36 PM
Christian: we need more pics, that is a very nice looking rig your runnin'
bodyguardracing 09-25-2002 06:38 PM
old sutphens kick ass
great to see some action on this site!!!!! OWN A 1982 OCEAN PACER 30. owned the boat since 1986. original 370 trs boat called FIND ME. almost 100% restored only interior stuff left to do. will post pictures as soon as possible. boat runs 75 on fresh water. less than 600 total hrs on hull, 175 hrs on repower 450 hp with GIL everything. T-MAN
ChristianGott 09-26-2002 01:56 AM
26' Sutphen
Thanks Fobes.
I'm picking up a new scanner this week and will have a pic or 2 available soon.
Stillcrazy 09-26-2002 09:53 AM
26 Sutphen
Sutphil,
Hope I resized themcorrectly. Your boat leaving Factory.
Stillcrazy 09-26-2002 10:06 AM
26 Sutphen
Must have taken dumb pills this morn. Didn't notice pics not in JPEG. So didn't make it.
floatingphil 09-26-2002 12:57 PM
Stillcrazy,
You must have resized them really really small because I still can't see them.
bodyguardracing 09-26-2002 05:04 PM
Posting Pictures
How do you post pictures with your messages?
T MAN
floatingphil 09-28-2002 07:19 AM
bodyguard,
Go to the General Discussion section and look in the Question and Answers part for help. There are previous threads on posting pictures. You may have to look back a ways.
ChristianGott 10-14-2002 08:15 PM
26' Sutphen
1 Attachment(s)
Another pic.....(still playin' with the process..)
BODYSHOT1 10-15-2002 11:46 AM
..nice ride Christian!
:cool:
