Konrad 540prs drives on 34 Sutphen
@ F-2 I'm going to give them a shot, and hold on to my transom assemblys and one set of drives incase they don't work. I just can't understand how they can negatively effect handling. They are 1.7 shorter than trs, which makes the bravo .9 shorter than konrad. It's a one day swap. Worst case is I swap back and resell them to you lol
242ls are you pulling my leg ?? Shaun I met you briefly last year at noppers poker run before we left Early. You had mentioned that you swapped to Bravo's on your outragous and had the x dimension if I ever needed it. For what reason are the Konrad's no good? I considered a bravo swap but the way I blow the trs lowers Pete Nopper said the Konrad's were much stronger than a bravo and the better choice. Don't want to do the swap and regret it.
