They also have a bigger main shaft. They have many upgrades from the XR's. If you think that this is a regular Bravo with a sticker on it this isn't the drive for you.
The splash plate on the back is a option from Imco they make different ones depending on the length of your drive. This is for a -2 Imco shortie they also make one for a -1 Imco. Nothing is cut it just gets extra holes to mount the splash plate. This came off a 2005 boat and had very low hours not sure exactly I've had it for two years and never used it. Its a very nice drive not all scratched up or any corrosion on it. I would easily us it I just bought a set of drives ready to go and I'm not going to use these. |
Originally Posted by imagecat
(Post 3977509)
As far as the upper "main shaft" being larger... There is a clutch shaft and an input shaft and they are the same size as Merc XR's. IMCO does build nice heavy cases. |
Imagecat. I sent a PM. Thanks, Bill
Originally Posted by DesertRage
(Post 3976870)
That's a Mercury Bravo upper case with Imco stickers on it.
The clutch shaft is different then a stock XR. |
Sale Pending
I called imco today and they rate these sc uppers at 600ft. Lbs and use xr gears with stronger cases. The scx upper is rated for 800ft. Lbs
I was also interested in this drive for myself Just thought I'd share what I was told from the guys at imco |
You want to separate ?
Text me if you want to separate, I'm interested in the one that's complete. 516-644-1875
U still have them..
They're sold
| All times are GMT -5. The time now is 06:29 PM. |
