#6 upper/lower gear sets
Please note that I have the following available for the #6 SSM drive as well as the usual #3, 3A, 4 and #5 upper gears, lower gears and propshafts.
1ea. #44-849672T01 (NEW) #6 dry sump propshaft.
I have the following upper gear sets:
2 sets (used) under 10 hours, #8M0051360 1.153:1 ratio upper gear sets.
2 sets (used) under 2 hours, #43-843201A01 1.24:1 ratio upper gear sets.
2 sets (NEW) #43-849175A1 1.35:1 ratio upper gear sets.
2 sets (used) under 20 hours, #43-849175A1 1.35:1 ratio upper gear sets.
2 sets (used) under 20 hours, #43-848787A1 1.50:1 ratio upper gear sets.
Note: all the above final ratios are calculated using the standard 19/20 tooth (#43-848249A1) lower gear set.
Note: It takes 2 sets (4 gears) to service one lower for a #6 drive.
I have the following lower gear sets.
2 sets (NEW) #43-848249A1 19/20 tooth count (1.053 ratio) lower gear sets.
2 sets (used) under 20 hours, #43-848249A1 19/20 tooth count (1.053 ratio) lower gear sets.
4 sets (used) under 20 hours, #43-841200T01 19/21 tooth count (1.105 ratio) lower gear sets.
2 sets (NEW) #43-841200T01 19/21 tooth count (1.105 ratio) lower gear sets.
Call for pricing.
Thanks.
Gary Kollofski
ph: 612-247-7081
Call for pricing.
Thanks.
Gary Kollofski
ph: 612-247-7081
