496 Manifolds + Risers - Water-rail style >
Old 11-06-2015 | 03:38 PM
TomZ's Avatar
Default 496 Manifolds + Risers - Water-rail style
I have a pair of 496 manifolds that I'm no longer going to use on my blown 454 (went to Stainless Marine). One manifold is basically brand new, the other a little older. All aluminum. Risers have been bead-blasted to remove paint and are a raw finish. The one heat sensor has been sealed up for the previous owner. The newer manifold needs to be plugged. The bells on the risers were removed in order to add extensions to deal with reversion so these will need to be extended to work with your setup. Will come with riser gaskets as well as metric nuts and washers to bolt them on (no turbulators).
Let's say $500 plus shipping for the whole thing.
I'll try to get some pics up later tonight if I can.
Thanks,
Tom
TomZ is offline
Old 11-07-2015 | 03:35 PM
TomZ's Avatar
ttt
TomZ is offline
Old 11-07-2015 | 05:07 PM
phughes69's Avatar
it is just one pair?
phughes69 is offline
Old 11-08-2015 | 02:31 PM
TomZ's Avatar
Yes. Just one pair.
TomZ is offline
Old 11-09-2015 | 11:17 AM
TomZ's Avatar
Default Pics added....
Any questions.... just shoot me a PM.
** Please note: I do not have ANY brackets for mounting electronics or shift assemblies. My shift assembly and oil filter assembly are both mounted to the transom, and my electronics are bolted to a bracket on the cylinder head. Thanks for looking!
[ATTACH=CONFIG]547460[/ATTACH][ATTACH=CONFIG]547468[/ATTACH][ATTACH=CONFIG]547467[/ATTACH][ATTACH=CONFIG]547466[/ATTACH][ATTACH=CONFIG]547465[/ATTACH][ATTACH=CONFIG]547464[/ATTACH][ATTACH=CONFIG]547463[/ATTACH][ATTACH=CONFIG]547462[/ATTACH][ATTACH=CONFIG]547461[/ATTACH][ATTACH=CONFIG]547469[/ATTACH]
Attached Thumbnails 496 Manifolds + Risers - Water-rail style-img_0345.jpg   496 Manifolds + Risers - Water-rail style-img_0346.jpg   496 Manifolds + Risers - Water-rail style-img_0347.jpg
496 Manifolds + Risers - Water-rail style-img_0348.jpg   496 Manifolds + Risers - Water-rail style-img_0349.jpg   496 Manifolds + Risers - Water-rail style-img_0350.jpg
496 Manifolds + Risers - Water-rail style-img_0351.jpg   496 Manifolds + Risers - Water-rail style-img_0352.jpg   496 Manifolds + Risers - Water-rail style-img_0353.jpg
TomZ is offline
Old 11-10-2015 | 01:55 PM
I'm interested. Sent you a PM Call or text me.
Thanks,
Travis
505 490 7710
89Force235 is offline
Old 11-10-2015 | 06:28 PM
TomZ's Avatar
Sold to 89Force235!!
Thanks Travis!
TomZ is offline
