548 ci motors
$18, 500 each
889 hp@ 8 psi Mark IV bowtie blocks. 548 ci 4.530 bore, 4.25 stroke 651 crane cam (244/256 632 lift 114 lsa) Piston oilers Spring oilers Machining by Borowski Race engines Fresh this spring from short block up. 2 year old boost referenced Quick fuel 1050 carbs Canton 10 qt oil pans Construction * Six Trap Door Baffles * Oil Recovery Pouch * Crank Scraper * Bolt In Slosh Baffle * Built In Louvered Windage Tray * Three 1/2" NPT Bungs * Provision For our Pan Mounted Dipstick * Powder Coating & Brass Plugs For Corrosion Protection Eagle cranks JE pistons Molnar Rods Dart iron eagle 345 heads with 40 hrs worth of combustion chamber and port work done by High Flow Heads. Ferrea super alloy exhaust valves Competition plus intake valves .135 wall Trend 3/8 pushrods Stainless Crower rockers. Intake: offset rockers for better valve pattern Tool room springs Stage 4 BDS 10-71 blower gone thru at Dyers. Restripped and replaced bearings 3 years ago. Schumann High flow oil pumps Daytona ignitions with map sensors. ( easily build 3D timming maps based on map/rpm/load/boost) Daytona Boxes also have many other features like idle stabilization, start reatrd etc etc. New MSD distributors IMI HI TQ starters Completely rewired and pre-wired for warning lights. (senders installed) Water/oil temps, pressure and Fuel pressure. Fuel set up for return to tank Set up for pre oiler or easy oil changes with built in pump. Brass seapumps Hexadjust timing chains Available with or without Drive Guardians ($2500 each) 8 plate bellhousing coolers for motor and trans reason for sale: Boat sold without power Ready to drop in, no corners cut on these builds whatsoever, ran perfect all summer. Priced to sell Edited: exhaust no longer available, price adjusted... |
https://www.youtube.com/watch?v=S72CbYUxSvY
ran great all summer
Open to selling without bellhousing and exhaust
All that work and expense... Now what you going to do?
Originally Posted by getrdunn
(Post 4509928)
| All times are GMT -5. The time now is 01:23 AM. |
