IMCO Power Flow
Old 01-07-2022 | 06:33 AM
Default IMCO Power Flow
Hi- what is a fair price for a used set of BBC power flow? They are black base with chrome tails. There are some scratches, but very good parts. Thank you
sandslot is offline
Old 01-07-2022 | 08:24 AM
I’d think 1,200 - 1,500 max fresh water.
getrdunn is offline
Old 01-07-2022 | 08:52 AM
I bought a set for $800, but then I had to buy the oil filter relocation kit and the PS pump bracket which was a couple hundred dollars. It all depends on whether you are going to include the 2 key pieces or not.
snapmorgan is offline
Old 01-08-2022 | 05:19 AM
Thank you
sandslot is offline
Old 01-08-2022 | 11:17 AM
Check the water jacket holes in both. If they are round, the manifolds are probably older. No issue, but older. Newer ones have triangle looking holes in them. Probably not a big difference in either, but just some info to have. I was exhaust dumb early on and ordered a brand new (and expensive) set on my old 454 years ago and like snapmorgan I had to use the IMCO ps bracket to get clearance. With my 502, I had to buy the oil filter relocation kit. The last set, I bought everything piecemeal. Manifolds first and then had to search for risers. Together, I believe it was about $1400. However, I found that someone had shortened one of the risers and did a crappy job of it. Sent it back to IMCO and they made it like new again for about $150. There is always a catch with used stuff. Good luck.
shunter2005 is offline
