OSO: Technical Issue with site?
OSO Content Provider
I noticed an issue in the Racer's Forums.
The header is lower than normal.
Apparently a code that is in place may be the problem ?
<br />
<b>Warning</b>: Call-time pass-by-reference has been deprecated; If you would like to pass it by reference, modify the declaration of convert_bits_to_array(). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. in <b>/var/www/www.offshoreonly.com/forums/forumdisplay.php(106) : eval()'d code</b> on line <b>62</b><br />
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html dir="ltr" lang="en">
Yesterday the site felt like I was on dial up.. Maybe just the transition to the new servers?
Better today though.
<br />
No Comment
From: This post copyright, Packinair Inc. All rights reserved.
you will never get a reply from IB in here. multiple threads and stickies in the help section
http://www.offshoreonly.com/forums/f...splay.php?f=54
Speedgirl already addressed it and IB says it is fixed.
I will post in there to let them know the problem still exists in the Racer's section.
I don't know much about programming, but I can assure you that a command does not start out with this:
<br />
No Comment
That much I know, but you don't use a back slash with it...
Why would you use a line break at the very beginning of your code ?
This is no longer at the top of the source code:
<br />
OSO header is now back at the top of the page where it should be.
Thanks!
Miller
02-17-2003 05:43 PM
