The B.S. Thread
Motherffuc;okn;'l;el;;'!!!!!!!!!!! I'm going to slap the person who coin the phrase "three out of four aint bad." All four fitting couldn't have worked, no, that would be too easy. Instead, three of them will work and the fourth, well, we'll just throw a different thread pattern on you a$$ just to keep you floored about working on your boat.
I sure hope NAPA has what I need tomorrow or there won't be any Sutphens at the poker run.
Yes, all four of the fittings you got are the same, which is what I asked for. Apparently the pump has two different thread patterns on each side. One is pipe, one is JIC. Oh well, maybe i won't be running this weekend. I'm going to run to NAPA in the morning and see if they have it.
[QUOTE=Rcolter;2851590]
Yeah, the corosive properties in lake Conroe are terrible, with the whole 12 minutes you put your boat in the water every year, you seriously need to make sure you got all that covered.
allways about the drama.
