Hi-Tech Trailer-Removable drive guard >
Old 08-11-2005, 08:13 AM
GoCiggie31's Avatar
Location: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Default Re: Hi-Tech Trailer-Removable drive guard
Those drives (and props) are way too awesome to not offer extra protection, my vote use the option since you got it.
GoCiggie31 is offline
Old 08-11-2005, 08:20 AM
OldSchool's Avatar
Originally Posted by Xray50
Sorry, Old School, didn't know Hi Tech made trailers. I found them.
http://www.aluminumboattrailer.com/
OldSchool is offline
Old 08-11-2005, 08:55 AM
Roger 1's Avatar
Hey Craig;
If space is an issue, I can come over and take those drives off too..
Your friend
Roger
Roger 1 is offline
Old 08-11-2005, 11:26 AM
Charter Member#157
MnFastBoat's Avatar
I wish my trailer hadthem
I know I would use them all the time.
little nisurance goes along way
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 08-11-2005, 11:56 AM
Moderator
ChrisK's Avatar
I would look at it like this.. whats the point of having a drive gaurd on the trailer in the winter?.. or at all if your gonna take it off.
ChrisK is offline
Old 08-11-2005, 01:05 PM
birdog's Avatar
ARE YOU NUTZ !!!
Wait untill that soccer mom in her SUV,Talking on the phone wipes out a pair of VIs !!!!!!
birdog is offline
Old 08-11-2005, 04:24 PM
hillbilly24's Avatar
When I worked as marine tech I saw alot more boats hit while parked on the side of the road then while in tow. do that.I can't explain it but probably 2/3 of all trailer accients seem to happen when the trailer is stationary. The dmage that a drive can do to the car the rails may be amussing but the damage to the drive isn't. Also by leaving it off, you are not the one who has to be more carefull, it means you have to trust everybody else on the road that much more and I wouldn't want to have Just my opinion.
hillbilly24 is offline
Old 08-13-2005, 10:19 AM
ratman's Avatar
nad hits and runs or doesn't have ins, or min liability policy...= your screwed. its a bit more work buy worth it. im gonna fabricate some for my trailer and i only have #3a's not those bad azz 6's
ratman is offline
Old 08-15-2005, 11:15 PM
Bulldog's Avatar
My rear bar was welded solid- I cut it out and fabricated some hinge plates to mount it in the same place it was originally- between the main rails. I have not re-installed it yet so no pictures.
This will give me the clearance needed to fold the back bar around a full 270 degrees, and latch to the port side rail.
I think also if I swing the bar around 180 degrees, it will face forward and I can then check the rear lights in the truck side mirror.
I will confess, one day I was debating on removing the drive guard. I needed to go to an auto parts store with my old dually (from hell) and got rear-ended by a member of the anti-destination league who was in the middle of a very important phone call, Obviously.
the final score-
15,000 lb rated Dually rear bumper-1 Dodge front-end-0
When I got back home I shifted my thinking to beefing the drive guard up, with rearward facing barbed spikes to 'detain' hit and run chicke$hits, instead of removing it.
Ronnie
Bulldog is offline
robpcfs
0
11-04-2007 05:00 PM
open87
01-11-2006 03:24 PM
addiction
03-10-2005 08:38 PM
offshoresteve
Skater
5
04-26-2004 05:20 PM
eyezlee
06-12-2002 01:27 PM
Quick Reply: Hi-Tech Trailer-Removable drive guard
