weight distribution hitch needed? >
Old 09-07-2005 | 01:07 PM
Default Re: weight distribution hitch needed?
Originally Posted by Rippem
go to the GM truck, or RV forums and read about the failures!
straight pull rated MUCH, MUCH lower than your quote.
and 9 out of 10, if it fails, the truck frame gets bent.
I agree, get a Putnam XDR. The cost is not that bad, about $ 190.
Wannabe
wannabe is offline
Old 09-07-2005 | 03:10 PM
wrinkleface's Avatar
Pulled a Fastech 312 and 353 around from 98-2002 w/ a 3/4 ton Burb. No probs. Stop and go stuff and alot of I-75 miles bet Detroit and northern Michigan. My 382 behind the Burb is another story. Hope to order an 06 2500 w/ the Max in early 06. Good luck, Wrink
wrinkleface is offline
Old 09-07-2005 | 10:35 PM
Thumbs up Re: weight distribution hitch needed?
Thanks for all the replies. "I'm glad I asked" is an understatement.
My '05 2500HD crew cab diesel with the "heavy duty" tow package has a hitch with a weight carrying capacity of 1000 lbs max tongue weight and 7500 lbs max trailer weight. Would I get by with this hitch....maybe. But by the time you add the trailer, fuel, beer , etc. I could be looking at 10,000+ lbs. Why do they put a POS hitch on a vehicle rated to tow 12,000 lbs?
The answer (thanks to you guys).... Putnam XDR
Weight carrying 1500 lbs TW and 15,000 lbs GTW
A little money for a lot of piece of mind...
Thanks for the replies from similar rigs. It's good to know my truck will tow this 292 well.
4mulafastech is offline
CAPTAIN CHUCK
9
10-24-2007 10:38 PM
382 newbie
3
02-11-2007 09:13 AM
tblrklakemo
9
02-10-2007 11:22 AM
miamioffshore
27
03-22-2006 01:50 PM
Boomer 880
5
11-14-2005 07:54 AM
