Exceeding your tow rating... a thought. >
Old 10-01-2005 | 09:36 AM
  #41
offshoredrillin's Avatar
Default Re: Exceeding your tow rating... a thought.
he has a dually and the ramp is literally a mile from his house.
offshoredrillin is offline
Old 10-02-2005 | 09:50 AM
  #42
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Originally Posted by articfriends
The thing that surprizes me is the fact a 3500 duramax dually,2500 8.1 avalanche and 2500hd 8.1 & duramax are all rated to TOW THE SAME AMOUNT! I recently had a argument with a guy who insisted everything was heavier duty on his 3500 duramax dually then my 2500 hd,he just couldn't believe they both use the same 11.5 inch ring and pinion,same size brakes,same transmission,frame,radiator etc. The only real difference is the overload springs on rear and extra set of tires,slightly narrower rear axle housing, Smitty
You would be right. I bought my Duramax for our marina this year & the dealer told us the same thing, plus the dually is more bouncy. I liked the dually for watching the wifes big(.)(.)'s bounce, but she didnt.. So we ended up with the HD2500 duramax. We regularly move bigger stuff & it has to date been working great.
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 10-02-2005 | 09:56 AM
  #43
Originally Posted by Hot Duck
That is what we did. The total weight of our current boat and trailer is around 21K pounds, so we sold the F-450 and stepped up to a little Pete to keep things safe and within the legal limits.
I can verify that if you are in an accident, the police will go through your stuff very thoroughly. We were rear-ended while towing the Gladiator a few years ago and the police checked all of our weight stickers, our registration cards and even brought out the portable scales to weigh the truck and trailer. This accident wasn't even our fault, but they still did all of this to be sure that the truck and trailer were within the legal limits. Luckily we had everything in order and everything was legit and within limits.
It is just not worth taking the chance of being over loaded. Even if you don't go far with your trailer, you can be involved in an accident 1 mile from home just as easily as if you were 100 miles from home. With all of the traveling that we did with the last two boats, we were only involved in this one accident and it happened less than 10 miles from home. Just something to think about.
Cool set up!!
Old 10-07-2005 | 01:56 PM
  #44
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I just came across these pics of my hitch before I sold it. This is the Factory CLASS-III hitch that GM installs on the Tahoe, Suburban, Yukon, Avalanche, Avalanche 2500, Suburban 2500, Denali, Denali XL, Yukon XL, Escalade, Escalade EXT, Escalade ESV, and most of the Silverados and Sierras from 1500 to 3500 unless you order a HD trailering package. Note the construction AND the LABEL. It says some BS name (NOT RATING) of V-5 Talon (just like Ford Called theirs a V-something), however, its still rated at CLASS-III.
Note the difference between towing with Weight Carrying and Weight Distributing.
Attached Thumbnails Exceeding your tow rating... a thought.-dsc00871.jpg   Exceeding your tow rating... a thought.-dsc00873.jpg
Sydwayz is offline
Old 10-09-2005 | 09:56 PM
  #45
No one pays attention to any specs ....until after the accident when the insurance company says " SORRY WE WILL NOT COVER ANYTHING, BECAUSE YOU WERE NOT TOWING WITH PROPER RATINGS NOR EQUIPMENT" as outlined in yours/ours policy
enticer is offline
Old 10-23-2005 | 07:30 PM
  #46
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Don't be this guy:
http://www.offshoreonly.com/forums/s...d.php?t=114999
http://www.offshoreonly.com/forums/a...hmentid=172546
Sydwayz is offline
Old 10-23-2005 | 07:54 PM
  #47
The V10 Ex handles it with air bags but I wish I had a Power-Stoke Dually.
Back4More is offline
5PMSMWHR
10
03-10-2007 04:14 AM
Blue by You
0
04-03-2006 08:15 AM
t500hps
8
09-18-2005 04:31 PM
CBR
2
04-15-2005 02:33 AM
