4x4 Tahoe need information
Crank up the front torsion bars a few turns (1 turn = 1/4") to get the A-arms off of the bumpstops, put on some adjustable Rancho RS9000 shocks and turn them all the way up.
Thanks for all the input.
I ordered IAS's from my engine guy. and I was told about the sway bar and will work that if the shocks don;t stiffen it enough.
Wannabe-- Doc John (a Fellow boater) is my dentist and he doesn't charge me!
Let me introduce Doc John..........
Originally Posted by drypipetiger
Remember the old saying, "you get what you pay for"?
I came across this company in one of my boat rags http://www.airliftcompany.com/
I was thinking about calling them about one of these products for my Tahoe. http://www.airliftcompany.com/new-index/Frameset.htm
I have an LT w/ the autoride system.
I had Air Bags on an Excursion that I used to pull my boat with and loved them.
However this truck is not for pulling, I have a dually for that. And if anything I think the softnest I don;t like is more from the front end than anything. I will try with IAS's and see, if it's not enough I'll work the torsion bar.
I would get the adjustable Rancho's. The IAS is more comparable to the Rancho 5000's which are really good shocks but if you are trying to get a stiffer ride I don't think you'll be happy with the set up of the IAS's. They are designed to be more user friendly than the ride of the 1 ton. The Rancho 9000's on the other hand can be jacked up to give you a really stiff ride. I guarantee you will not wish you had abought a better shock if you buy the 9000's, the Edelbrocks on the other hand are a coin toss on whether or not they will work for you. The cost of adding a bigger sway bar plus the IAS shocks will be much more expensive than 2 Rancho 9000 shocks anyways..........
