4x4 Tahoe need information
Old 11-30-2005 | 09:34 AM
Tantrum's Avatar
Default Re: 4x4 Tahoe need information
Originally Posted by BADKACHINA
I would get the adjustable Rancho's. The IAS is more comparable to the Rancho 5000's which are really good shocks but if you are trying to get a stiffer ride I don't think you'll be happy with the set up of the IAS's. They are designed to be more user friendly than the ride of the 1 ton. The Rancho 9000's on the other hand can be jacked up to give you a really stiff ride. I guarantee you will not wish you had abought a better shock if you buy the 9000's, the Edelbrocks on the other hand are a coin toss on whether or not they will work for you. The cost of adding a bigger sway bar plus the IAS shocks will be much more expensive than 2 Rancho 9000 shocks anyways..........
I agree with the Rancho 9000 adjustable shocks. I had a Z71 and that is already a stiff suspension (comparatively). Your gonna need more shock if you want to stiffen the ride.
Tantrum is offline
Old 11-30-2005 | 02:07 PM
stecz20's Avatar
hey ,you guys must feel like homos driving around in those gms...
stecz20 is offline
Old 11-30-2005 | 02:25 PM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
IMO, increase your sway bar diameters f&r (especially front) and add Bilstein's hd offroad gas shocks- very firm dampning yet not bone jaring
GoCiggie31 is offline
Old 11-30-2005 | 09:18 PM
augie58's Avatar
if you do the torsion bars you need to have the front alignment reset because raising the adjusters alters the alignment spec's causing tire wear.
augie58 is offline
Old 12-01-2005 | 07:53 AM
GLH's Avatar
GLH
I was told that by my mechanic, I received the IAS yesterday and they are going on Monday... I'll see how that changes the ride and then work from there if it isn't stiff enough.
Thanks for all the input.
Stecz.... GM rules.
GLH is offline
Old 12-01-2005 | 12:08 PM
drypipetiger's Avatar
Congrats on moving up in the world...
drypipetiger is offline
Old 12-01-2005 | 08:27 PM
GLH's Avatar
GLH
Hope you will to soon... must be a biatch rowing that big canoe...
GLH is offline
Old 12-01-2005 | 09:20 PM
Let me know when you see me turning a wrench...
Old 12-05-2005 | 10:16 PM
GLH's Avatar
GLH
The sh!t you turn I want nothing to do with!
And if I didn't fix that trailer from the Hooter's rub you sure as sh!t where not the one to help us get going again! Wait till you pull your beast 1600 miles down and 1600 back, if you don't mess with your rig then I'll be impressed or it'll take you a little longer than the 22 hours we did it in.
GLH is offline
Old 12-05-2005 | 10:17 PM
GLH's Avatar
GLH
IAS's are installed runs stiffer enough to satisfy me...
Thanks for all the suggestions.
GLH is offline
