Electric Trailer Breaks
Old 01-19-2006 | 11:49 AM
itilldo's Avatar
Default Electric Trailer Breaks
I presently have surge breaks on my trailer how hard/expensive is it to convert to electric brakes or can it be done? Also, is it really worth doing?
itilldo is offline
Old 01-19-2006 | 01:18 PM
scottc's Avatar
Default Re: Electric Trailer Breaks
Not hard at all. Cost @750 if you do it your self. @1200 for someone else to do it. They work much better that surge. It's really an electric over hydrolic system.
scottc is offline
Old 01-19-2006 | 01:44 PM
Sydwayz's Avatar
Forum Regulator
Scott, what does it take?
I have a Dico Model 10 coupler with Kodiak discs on two axles. Total weight is 12K with boat and trailer and fuel. I'd like to do away with the surge coupler if possible. Can you do it in the parking lot during the Chill-Out? (JK)
Sydwayz is offline
Old 01-19-2006 | 02:02 PM
scottc's Avatar
A solid coupler needs to be installed (unbolt the old bolt on the new) Install ele/hyd unit, hook up brake line, bleed system. replace trailer plug with a seven pin plug, wire as needed. Install brakeway system ( battery, cable and switch) That would do it...........for your system about 1500-1600 total.
AND NO..............I WON'T DO IT THERE I'll be there to party (would you really want a drunken person working on your trailer??)
scottc is offline
Old 01-19-2006 | 02:40 PM
dyno's Avatar
Charter Member #655
I did mine last year for $600(electric) best money I ever spent on my trailer!!!Its a cake job I did it in a couple nights after work and put in all new bearings and races too.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 01-19-2006 | 07:04 PM
wrinkleface's Avatar
Hey Don, did U do straight electric or electric/hyd.? Hope Mama is doing well! Tracy
wrinkleface is offline
Old 02-05-2006 | 01:14 PM
Dyno, where did you purchase your parts for the conversion? Do they have a web site I can order from? Thanks
Corsa 31 is offline
mcraymond3
12
04-04-2008 09:40 PM
dukenrock
6
05-04-2007 05:46 AM
pullmytrigger
17
03-12-2007 09:50 AM
pachangalpina
7
09-24-2004 09:00 PM
scarabrick
11-15-2002 02:35 PM
