-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Pintle Hitch (https://www.offshoreonly.com/forums/trucks-trailers-transportation/127274-pintle-hitch.html)
Bottomfeeder 04-16-2006 11:41 AM
Re: Pintle Hitch
Originally Posted by Prater
I ordered the XDR
I also got the 15k recievers in 2,4,and 6 inch drops with correct balls, havent got my new boat yet and dont know the drop if any,, gonna be tight for the 27th
Sydwayz 04-16-2006 12:30 PM
Re: Pintle Hitch
Be aware. The bolts that ship with the Putnam XDR hitch are Grade 5. I upgraded all of mine to Grade 8. Its worth the time to track them down.
I am on my 2nd Putnam XDR (on 2nd truck). Great hitch.
Bottomfeeder 04-16-2006 01:21 PM
Re: Pintle Hitch
what about just using the factory nuts/bolts?
Prater 04-16-2006 02:55 PM
Re: Pintle Hitch
Thanks again for the info. There is an industrial nut and bolt place nearby. I will go there and get the grade 8 hardware.
Sydwayz 04-16-2006 05:32 PM
Re: Pintle Hitch
In the case of my Ford F-350:
In order to get the full load carrying capacity of the Putnam XDR, you have to use the square collars that come with the new bolts of the Putnam. There is a square collar for the top and bottom of each bolt. If you use these like you are supposed to, the factory bolts are not long enough to use instead of the Putnam grade 5 bolts.
The factory bolts are more convienent though, since the nuts are welded to a fixed bar. Again, its best to have new grade 8 bolts long enough to use the square collars on north and south sides of each bolt.
Its 5000 times easier (in the case of a Ford) to R&R the hitch if you remove the under frame mounted spare tire first.
Byrdman 04-16-2006 05:44 PM
Re: Pintle Hitch
Originally Posted by KNOT-RIGHT
TOM I just hooked my boat up to my Dodge3500 dually.
It straighten the leafs and flatend the helpers.
This Skaters got the Pintle hitch I got that same receaver.
Its a joke! No engines and drives puts the Tonge weight
thru the roof. Forget it I would not even attempt it.
I went and got the Ten wheeler mack to bring it to the gas station.
Im gonna grab a Single axle Pete or a w900 KW.
Yes.......I agree...without the motors and drives forget it......put 2 ..55 drums of water on the back trailer platform with lids for temp moving in yard.......oh snap....wl 900...hot heavy horse.....big daddy!.....
Chris Sunkin 04-16-2006 05:45 PM
Re: Pintle Hitch
FYI- If you weld on a Gr. 8 bolt, it's no longer Gr. 8. It's not even going to hold Gr. 5 specs.
Byrdman 04-16-2006 05:50 PM
Re: Pintle Hitch
Why don't you guys make your own hitches around here....these recievers are lots of junk from what I see..get fabbing yourself....have a welder beef up the reciever to frame support.....I see lots of sagging pintles and hitches....somebody post a pic of the best reciever on the market so far.
BZ 04-18-2006 12:24 PM
Re: Pintle Hitch
got the draw bar from northern tool in today, looks great can't wait to use it....BZ
Prater 04-23-2006 03:46 PM
Re: Pintle Hitch
1 Attachment(s)
OK, I now have the XDR on but what is everyone doing for their plug? I use my factory plug on different trailers and there is no where to attach it to the XDR.
