View Poll Results: Pull Rig
Chevy
39.66%
Dodge
15.95%
Ford
44.40%
Voters: 232. You may not vote on this poll
New Pull Rig Poll
Old 11-01-2006 | 04:44 PM
  #51
Joe's Avatar
Joe
Offshore Cowboy
Default Re: New Pull Rig Poll
Originally Posted by Wobble
This is going to be my next truck
2007 GMC 3500HD with the 365HP Duramax/Allison
any more pics???
Joe is offline
Old 11-14-2006 | 10:52 AM
  #52
SmoothWaterSports's Avatar
Another opinion -
If I was going to use a truck as a daily driver and occasional towing as described, I'd buy a GMC/Chevy for the comfort value and towability. They drive and ride more like a car than Ford does. A 3/4 ton Avalanche is a good compromise with good towing capacity.
While I like the looks of a Dodge, all my personal experiences have been negative, so it's not a consideration for us.
That said, I've been driving Fords a fairly long time, and will likely stick with them. My F150 with the Triton 5.3 was sold with 165000 on it, and it was still tight and ran great. My current 02 F350 is my daily driver and yet we have towed tremendously with it. It has 160k on the 7.3 powerstroke and auto, and I'd like to sell it and buy a new 06/07 Powerstroke with identical options.
Another consideration is a dually will have greater stability than a SRW when towing big stuff. Ford is the only one currently that builds a 1 ton crew cab shortbox. The advantage? Not driving a limo every day.
Peter.
SmoothWaterSports is offline
Old 11-14-2006 | 02:26 PM
  #53
Cattitude's Avatar
Originally Posted by Catmando
The 2007 Dodge 2500-3500 trucks will have a new 6.7L 350/650 Cummins with two new transmissions- a 5speed and a 6speed automatic. These upgrades will be available in January(5.9L will be discontinued in December). That brings the Cummins up to the power and torque that Ford and GM are offering.
There is a reason heavy loads are mostly towed with an inline 6 cylinder diesel motor; it makes more torque at a lower RPM than 8 cylinder diesels. All of the big-rig motors are 6 cylinder diesels.
The 5.9L Cummins motor has 30% less moving parts than the 8 cylinder motors of Ford and GM. It is lighter and gets better fuel mileage.
Yup, The Cummins alone is reason enough to look at the Dodge-
Ford sells more trucks cause they chase the fleet market heavy and the others don't. The truck is nice, the 6.4 is scary, especially after Ford helped IH so much with the 6.0 and look how that turned out.
The chevy has a great tranny, rides like a family car (I consider that a negative but respect that some don't) and the cheesy interior seats. Seams like they also have a hard time picking a design theme and sticking with it so they throw everything on the truck (monochromatic with chrome and grey plastic pieces)- the new lines do look good IMHO
If you have friends in the used car biz- they'll confirm there are fewer 100k mile Dodges at the auctions and they fetch more $, cause the engines have plenty left and the market knows it. Depending on your situation- this might not matter to you.
Get what you like, by an extended warranty if you're concerned about someone's new engine or tranny. Have fun and tow safely.
Cattitude is offline
Old 11-14-2006 | 07:21 PM
  #54
The d max is just starting to busy....they have already run the miles...and I have not heard any real issues...motors are first class....tons of engineering and design= big power outputs when pushed on....real big
Byrdman is offline
Old 11-17-2006 | 08:26 PM
  #55
SOX's Avatar
SOX
Semper Fi
I just bought a Ford F-250 PSD, So far I like it very much. Much more room in the 4 door than the standard Dodge 4 door.. To match the Ford's room a Mega cab is needed. I was talking with a guy with a '06 ram 3500 Cummins manual trans. He said he got 13mpg hauling his fith wheel camper and gets 19 mpg around town. But while he likes the powertrain he is disapointed with the rest of the trucks construction. For excample he said if rain water gets on the seats when he opens the door it will stain the seats and needs to be worn away. I think Dodge is the best prices truck out there as well.
I don't have much of an opinion with the Chevy's but I havn't heared any complaints about them.And all I ever here is how great that trany is.
Here is my new (to me) Ford PSD I just got it last week with 2100 miles on it. Saved a lot of money buying it used.
Attached Thumbnails New Pull Rig Poll-fall-series-06-063-medium-.jpg   New Pull Rig Poll-fall-series-06-064-medium-.jpg
SOX is offline
Old 11-19-2006 | 02:59 PM
  #56
John.Vaught's Avatar
I am a firm believer in Dodge and the Cummins engine and so is ford so much so that all of our F-650 trucks have a 5.9L cummins identical to the one in my 2500 under the hood.
John.Vaught is offline
Old 11-19-2006 | 03:07 PM
  #57
Detailed Specifications
Truck Type Carrier Tire Size 19.5LP
Engine Cummins 5.9L 230 Frame Steel
Engine Brake Yes Interior PREMIUM
Transmission 2200RDS Color White
Suspension Spring Serial No. 7V465052
Rear End Ratio 4.33 Wheel Base 224"
Axles Single Make/Model Jerr Dan
GVWR 25,500 lbs Refrigerated No
FA Capacity 8,500 lbs A/C Yes
RA Capacity 17,500 lbs Power Steering Yes
Front Wheels Steel Tank Capacity 50 gallons
Rear Wheels Steel
Additional Equipment
Wheel Lift Remote Free Spool
Comments
hydraulic clutch shift PTO, smooth steel deck, Air compressor
Warranty Information
Engine Warranty: Balance of Engine Warranty
Driveline Warranty: Balance of Warranty
Loan Calculator
Loan Amount:
Term (Months): Select One 84 months 72 months 60 months 54 months 48 months 42 months 36 months 30 months 24 months 18 months
Select Rate: Select One 25.00% 24.00% 23.00% 22.00% 21.00% 20.00% 19.00% 18.00% 17.00% 16.00% 15.00% 14.00% 13.00% 12.00% 11.00% 10.00% 9.00% 8.00% 7.00% 6.00% 5.00% 4.00% 3.00% 2.00% 1.00%
Monthly Payment:
This loan payment calculator can determine what your approximate monthly payment would be for a standard loan.
(Please note that certain financing plans may have a different methods of payment calculation).
*This is an estimate only, so please speak with one of our financial representatives for an exact quote.
2007 Ford F650
Unit# 65052
Sleeper
Price: $61,425
Contact Information
Prairie International
Address [ Map It ]
808 West Bradley
Champaign, IL 61820
Phone#
(217) 352-4187
Fax#
(217) 352-0490
Back to Home Page
Tools
Print Specification Sheet
Email this to a Friend
I'm Interested in this Truck
Sales Staff list
Bill Cavanaugh - (Sales)
Email: [email protected]
Mobile: 815-263-6433
Matt Phillips - (Sales)
Mobile: 217-433-9533
John Hankes - (Sales)
Mobile: 815-584-7011
Similar Units
2005 International 4200
International VT365 215
Unit#: 38169 $55,118
2005 International 4300 Ext Cab
International DT 466 225
Unit#: 38330 $56,019
2006 Ford F450
International Powerstrok
Unit#: 68621 $56,367
International DT 466 220
Unit#: 38384 $62,021
2007 International 4300
Unit#: 34190 $67,283
View All Simlar Units
DISCLAIMER: Photos, specifications, prices, and all other information are subject to change or correction without notice. All liability is expressly disclaimed.
Copyright © 2005 Interstate Online Software, Inc. Web site is powered by SOARR Truck Sales & Management System (740) 587-1695.
Old 11-26-2006 | 08:38 PM
  #58
I have personally owned the GMC and a couple of Ford 350's. I have never owned the Dodge but I know you can't beat the Cummins engine. The Gmc 3500 dually was the most enjoyable to drive. It had the most comfortable seats and all of the controls seemed to be right at your finger tips. It handled well and had a great ride. Unfortunately my 42' Cig was too much for it. The towing capacity on the GM's is only 12k lbs on the ball mount and I was way over. The frame actually bent and so did the hitch. As much as I liked the truck it just wasn't as tuff as the Ford so I sold it and bought an 05 dually King Ranch with the tow boss. There's a huge difference. The GMC used to sway a lot but the Ford never budges. The steel on the Ford is stronger and so are the components IE the suspension and so forth. I just wish it was more comfortable to drive. The seats suck and the steering feels like something out of a semi. I've since sold the Tiger and bought a Top Gun and have been shopping for a new truck. Now that I don't need the tow boss I wanted to get something more comfortable, like the GM. But I'm still over the legal towing capacity. Too bad you can't take the interior and the tranny from the GM, the engine from the Dodge and put it on the Ford chassis, now that would be a hell of a truck.
tim mccray is offline
Old 11-27-2006 | 12:33 AM
  #59
the frame damage too had alot to do with the hitch . The stock one is junk and is MAXED at 7500 lbs. I would not even tow that with it. The first thing all 3 of my late model GMs have gotten is a REAL hitch (Putnam XDR is my choice), that bolts just to the frame (and not the bumper too like a stocker to make a wieght rating ) and runs farther forward on the frame rails.
I cannot believe you put that kind of ball wieght on a stock hitch. You're lucky something really bad didn't happen!
Rippem is offline
Old 11-27-2006 | 04:41 AM
  #60
Jassman's Avatar
Where have I heard that before exactly. Jeff
Jassman is offline
