F450 vs. F350 ???
Old 12-17-2006 | 09:43 PM
BRD
Default F450 vs. F350 ???
Guys .... help me out here .... on the new 2008 Ford Super Duty .... Whats the difference between a 350 and 450 ?
Thanks !
BRD is offline
Old 12-18-2006 | 05:23 PM
Default Re: F450 vs. F350 ???
Rainman answer:
About a 100 dollars
Sorry...
wannabe is offline
Old 12-18-2006 | 05:41 PM
Jassman's Avatar
25 hp less, by what the present specs state. Im sure the suspension is different as well.
Jassman is offline
Old 12-19-2006 | 12:31 PM
ZBODaytona's Avatar
Bigger stuff in the 450...As in axles, brakes, and gearing. Also the towing ability is higher. Don't quote me on this but the 350 has moved up from 15,500 to 18,500 (i am assuming this is the tow boss) and the 450 is something around 22,000 or 24,000lbs (this could be higher as well) going the top of my head from an article i saw the other day.
as jassman said the motor has less power. the tranny is the same. same type of suspension though i am sure the springs are rated different.
ZBODaytona is offline
Old 12-19-2006 | 07:28 PM
offshoredrillin's Avatar
Buy a GM duramax Jerry..end all the confusion
offshoredrillin is offline
Old 12-19-2006 | 07:37 PM
tblrklakemo's Avatar
SeaRay Sundancer
Probably same motor just slightly more restrictive intake or exhaust that cuts some power. I would do the 450..bigger is always better when towing.
tblrklakemo is offline
Old 12-19-2006 | 09:06 PM
For heavyweight pulling don't do the 450 as the rear ends tend to develop more heat and thus "burn up" faster. If towing heavy stuff consistantly the 550 has a much better record for longevity
Lute Dickey is offline
Old 12-19-2006 | 10:53 PM
Someone should post a laymans chart for the F series citing all the main points, it's always confused the chit out of me as well.
Anarchy Powerboats is offline
Old 12-20-2006 | 11:13 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I can only guess, but I think this is Ford's plan:
They see a lot of us towing big boats, trailers, and RV trailers. A lot of folks are also sticking on 19.5 and 22.5 inch rims. I think they made the F-450 a factory consumer pleasing vehicle (King Ranch/Lariat options, factory installed bed, chrome wheels) with high tow ratings and easy wheel swap options (no adapters needed to run 10-bolt wheels) in an effort to entice folks into buying the F-450 with the new engine. It might work, but after their total face-flop with the 6.0 introduction; I would not want to risk a 1st year diesel from Ford, even if I was in the market. Now that these new trucks are falling into all of these new emissions laws and new fuel requirements; all of the aftermarket tuning and parts may change drastically, or come to a halt on new trucks. The 25HP less rating on the F-450 compared to the F-350 is more than likely all in the computer; and can be programmed back in and then some once the tuners get a hold of them. However, this is going to wreak havoc on these new emissions systems. Remember how they added smog pumps and catalytic converters in the early to mid 1970s? This is virtually the same thing with new diesel trucks.
If I were shopping, I would be holding onto what I have at least until the 2009 models of the new motors/F-450s and such. You will then have an accurate picture of what aftermarket accessories and tuning will be available as well.
Sydwayz is offline
Old 12-20-2006 | 12:09 PM
SeaRay Sundancer
Everything you need and more.
http://media.ford.com/products/press...398&make_id=92
GVWR's available
10,000-11,500(F-350 SRW), -13,000 (F-350 DRW) 16,000 (F-450), 17,950, 19,000 (F-550)
Max. GCWR's available
23,000 (F350 SRW), 23500 (F-350 DRW), 30,000 (F-450), 33,000 (F- 450/550)
Max towing capacity, properly equipped
15700 (F-350 SRW), 16,000 (F-350 DRW), 21600 (F-450), 24,600 (F-550)
All Dimensions are in inches unless otherwise noted.
mcraymond3
17
02-03-2008 09:38 AM
BillR
15
10-17-2007 10:55 AM
382 newbie
13
04-23-2007 05:04 PM
Jassman
59
03-07-2007 07:16 AM
JC
05-05-2004 06:44 AM
