Originally Posted by Blue by You
(Post 2119857)
Here's what my hitch says? I'm guessing I have both using the drawbar? Should I still get rid of this and go with the Putnam XDR hitch?
Only thing is the Putnam ships with Grade-5 bolts. Grade-8 is better. I have a local supplier who can replace the Grade-5s with Grade-8s. If you pick up the Putnam (they ship direct), let me know, and I will pick up some more on my way to the lake. They are only a few bucks. |
Just took Sy.'s advice on the Putnam XDR for my 06 PSD. My local truck accessory outfit ordered and put it on for me. $225 installed. The hitch looks very stout, there was clearance for the spare tire to drop, and even the paint job looked decent. The receiver is a little higher and sticks out a little farther. This is much cheaper than the Reese(350.) Thanks for the advice. Eric
Originally Posted by Sydwayz
(Post 2120008)
Yeap, the Putnam XDR is what I have on mine. The Putnam is much more stout than the factory hitch. That hitch is only rated for 6000 lbs. for the hitch setup on your boat trailer (weight carrying).
| All times are GMT -5. The time now is 11:03 AM. |
